      09-10-2016, 10:50 AM   #1
-c-
-c-'s Avatar
Drives: bmw
H&R camber bolts
Hey guys lowered the X today and need to buy some H&R camber bolts, does anybody know where to buy them?
I've looked around and haven't seen anybody sell them.
Any info would be great !!!
Thanks!
      09-10-2016, 01:49 PM   #2
mitch808
Drives: 2012 X5 35i
I bought my set from amazon
      09-10-2016, 05:16 PM   #3
-c-
-c-'s Avatar
Drives: bmw
Ok does one size fits all?
Also is their any need for such a bolt for the rear suspension?
Thanks!
      09-11-2016, 12:35 AM   #4
azm3
azm3's Avatar
14
Drives: 96 SC M3, 20 X5MC
You need the 14mm Bolts (Model TC114) https://www.amazon.com/TC114-Triple-.../dp/B00CBQ6MAS
20 /// X5MC Tanzanite Blue II Metallic - RachChip, MSS Springs, Cat-back Titanium Exhaust
17 X5 50i Space Grey Metallic - ESS Tune, Catless Downpipes, X5M Air Filters, H&R Springs & Spacers , BBK
96 SC ///M3 - CP Pistons & Rods, ARP Studs, VAC SC Cams, VF V3 Blower, 12lb Pulley, RK Tune & lots, lots more...
      09-11-2016, 09:59 AM   #5
-c-
-c-'s Avatar
Drives: bmw
Wonderful .... Thank you !
Also is their anything for the rear wheels to get them back in spec? Or are these only for the front ?
Thanks again!
Never mind I read it has both positions for front and rear.
Thanks again!!
      09-11-2016, 11:11 PM   #6
azm3
azm3's Avatar
14
Front is all you will need them for and typically only if you are doing a big drop.
With the 1.2" h&r springs, you can get dial out ideal negative camber on the factory control arms with no modifications. If you do 2" drop, you will need the camber bolts in the front for sure.
