      09-10-2015, 01:11 AM   #1
KayTees
Tuned ///M Cars Only
KayTees's Avatar
Drives: '21 F87 M2C |'20 F97 X3MC
Tailgate De-badge tutorial?
Hi was just looking to see if anyone has a tutorial/video on how to remove the BMW badge on the tailgate, tried to find some on Youtube but only found the removal of the hood badge. Reason being that my back emblem is a dented near the "M" and I would like to swap all the emblems to the black on black one
      09-10-2015, 01:15 PM   #2
muddycharles
Drives: 2011 X5 M sport
subscribed to this thread - same problem
lets see who has the answer. Im afraid it might involve taking the tailgate apart.
      09-10-2015, 07:28 PM   #3
socale39
Drives: 04 545i SMG
Emblems just have a sticky back tape on them so with a little tooth floss or fishing line you should be able to slide it on the backside and pull it off by curtail through the tape. This is how it is on most BMWs so I'd imagine it's the same for the E70.
      09-10-2015, 08:56 PM   #4
Crazy1323
Drives: X5M
I'd also like to know how to take this off. I'd like to paint the chrome surround gloss black like the rest of my ind stuff
      09-10-2015, 11:07 PM   #5
X5MFan
Drives: X5M 2012
In addition to the sticky tape there are two pegs that are friction fitted to the tailgate. I believe they are at 3 and 9 o'clock so use a non marring tool and pry there.
      09-11-2015, 12:35 AM   #6
KayTees
KayTees's Avatar
Where would you floss it tho? On the whole chrome roundel or the inner circle.
Does this work the same on the back or is it just the front?
      09-11-2015, 08:52 AM   #7
X5MFan
Drives: X5M 2012
The sticky tape is about 1cm wide around the outside of the roundel. Floss just as shown and go around in a circle. The pegs will prevent you from going straight across. Should come off easy.
      09-11-2015, 01:41 PM   #8
xpl0sive
Drives: bmw
heat it up with a hairdrier or a heat gun first, it should come off easy once warm. If using a heat gun, be careful, it will get HOT!
      09-11-2015, 03:12 PM   #9
BAKZOOM
BAKZOOM's Avatar
Drives: 2013 - X5M - Melbourne
Below are instructions to remove the entire rear emblem which includes the trim and the roundel. You can use dental floss, fishing line or the IND Distribution tools.
http://f15.bimmerpost.com/forums/sho....php?t=1112728
If you haven't bought one yet, below is an IND pre painted rear emblem. It's painted black. The trim and roundel are sold as one unit. I was thinking about getting this but sticking with OEM look for now.
http://ind-distribution.com/ind/bran...k-roundel-trim
      09-11-2015, 08:30 PM   #10
socale39
Drives: 04 545i SMG
Personally I think the OEM rounded looks best. Blacked out, carbon fiber, etc all look cheesy IMO.
      09-12-2015, 05:23 PM   #11
KayTees
KayTees's Avatar
Answer I was looking for thanks! They make the back look so complicated lol, Personally I still like this black one instead or might actually order the original and the black on black.
      09-12-2015, 05:45 PM   #12
jiggz
Drives: E90 M3|F15 X5 50i
Agree 100%.
      09-12-2015, 09:57 PM   #13
DrMattN40
DrMattN40's Avatar
18
Drives: 2012 X5M
My tailgate M badge is water damaged (somehow got into the color under the protective layer and discolored it)... where to get a new one cheap (but not looking cheap)?
Black on Sakhir Orange Leather with Piano Black trim, Lux Angel Eyes, BMC Air Filters, Fabspeed Supercup Exhaust.
      09-13-2015, 01:20 PM   #14
BAKZOOM
BAKZOOM's Avatar
I'm keeping the round center trim and roundel as is but dipping/painting X5M emblem black.
I thought about a black roundel and black trim around it but thought it's too much.
      09-13-2015, 02:59 PM   #15
Cattivo
FDNY Engine 55
Cattivo's Avatar
Same here...I don't really see many x5m's but when I do all of them have had discolored m's on the trunk
      09-13-2015, 08:19 PM   #16
BAKZOOM
BAKZOOM's Avatar
Mine too is discolored/faded. The stripes on the M badge are faded. I think there is a layer of sealant applied by BMW after they paint the stripes on the M badge and if that seal is broken it allows air to get in under the seal which causes the fading.
I tried dipping the emblem and it worked but some of the dip, when still liquid, seeped into the sealed area. Now there's a bit of black dip under the seal and on the faded stripes. Working with dealership to get M badge and stripes replaced under warranty.
      09-14-2015, 03:15 AM   #17
KayTees
KayTees's Avatar
Just gonna carbon fiber all the quarter pieces as a temporary fix, the idea of a black emblem was inspired by mark_tdot but I zoomed in and figured that it was actually looks to be carbon fiber. I have over 5ft of carbon fiber left over from my interior wrap and thought its a not that bad of an idea for a temporary fix until I order myself a OEM/Good Quality Roundel. Also, I was thinking as for the fade, would a protective shield for the emblem prevent fades on the roundel? There's one from Bavarian which doesn't look like half bad. Haven't seen one for the M emblem tho.
EDIT:
      09-14-2015, 03:58 PM   #18
BAKZOOM
BAKZOOM's Avatar
Looks much better than the dented one. Glad you kept the trip chrome.
      09-14-2015, 11:25 PM   #19
socale39
Drives: 04 545i SMG
To each their own I guess...
