      02-09-2015, 03:13 PM   #1
mitch808
Drives: 2012 X5 35i
Walnut Blasting on N55 35iX?
There is a lot of talk of needing the walnut blasting service done on the N54 engine every 30k miles. The N55 nothing stated I can find officially, but folks are saying about every 50k miles.
Is it needed on our e70's? Lots of the 1 and 3 series folks talk about it...
      02-09-2015, 03:32 PM   #2
spaniard
spaniard's Avatar
Drives: 2015 BMW X6M
Yes, there is a DIY for it: http://blog.bavauto.com/15543/bmw-di...-walnut-blast/
there is for N55 too.
      02-09-2015, 03:59 PM   #3
mitch808
Drives: 2012 X5 35i
There is only ONE search result on this forum(x5 section) about the service, the rest of the hits are in the 1/3 series forums and other BMW centric forums.
Granted we're a smaller bunch than the 1/3 series counterparts; It's just not mentioned for the e70 at all in any meaningful way.
      02-09-2015, 04:07 PM   #4
Jalndrs
Drives: 2015 F15 35i
From following the E90 n55 forum it looks like it's not needed till 75k+ miles. They don't build up as quick as the N54.
      02-09-2015, 04:43 PM   #5
spaniard
spaniard's Avatar
it does not matter it does not say e70... it is the engine and it same as e90, etc. the process is 95% same and the only difference is the vanity cover.
      02-09-2015, 08:47 PM   #6
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
What happens if you never get this done?
      02-10-2015, 10:28 AM   #7
Poppyboy
1976 Triumph TR6  [10.00]
1993 Bentley Turbo R  [10.00]
2011 X5  [10.00]
I find it hard to believe that this is even necessary at such a low mileage interval. Just the risk to electronic and plastic componentry with removal and reinstallation make it appear to be an unnecessary risk. Despite the (slightly) higher carbon buildup on valves inherent with direct injection, why wouldn't using premium fuel and periodic fuel system cleaner mitigate this until beyond 100k miles?
      02-10-2015, 10:42 AM   #8
mitch808
Drives: 2012 X5 35i
Because all the fancy fuels with detergents, and fancy fuel system cleaners, are injected DIRECTLY INTO THE CYLINDER. Hence the name DI or Direct Injection.
They do not touch the back of the valves or ports.
Add to the fact that any unburned fuel from say a ping event, can/will/possibly make carbon deposits behind the valves.
      02-10-2015, 01:02 PM   #9
Poppyboy
2011 X5  [10.00]
I know what direct injection is. The spent mixture most certainly makes contact with valves after detonation as the exhaust valve opens, which results in some carbon buildup. However, that buildup shouldn't materially affect valvetrain performance at such low mileage, IMO.
      02-10-2015, 02:59 PM   #10
lanbrown
Drives: BMW X5
You are forgetting about the intake side of the equation. Since no fuel is hitting it, no additives are there to clean the intake side.
      02-10-2015, 04:30 PM   #11
Poppyboy
2011 X5  [10.00]
There's no carbon to build up until after detonation (3rd stoke), no?
      02-10-2015, 04:41 PM   #12
lanbrown
Drives: BMW X5
No. You have intake valve coking. This wasn't an issue before as you had fuel cleaning the intake valve; there is no nothing to clean the intake valve. Care to guess what causes the intake valve coking?
      02-10-2015, 05:48 PM   #13
Poppyboy
2011 X5  [10.00]
No one knows for sure. Some postulate crankcase ventilation gasses.
      02-13-2015, 12:47 PM   #14
DustinMN
Drives: 2007 335i 6MT 2011 X5 Msport
Just had this done on our 2011 35i with 42k miles on it. Not nearly as dirty as my N54 was with 55k on the clock.
I'd say every 50-70k is fair for the N55. Per my SA they do not suffer from build up nearly as bad as the N54.
      02-13-2015, 01:05 PM   #15
mitch808
Drives: 2012 X5 35i
Hmm.. Well I'm at 58k so I might just do this if I can find a good deal on the service. A few years back BMW of Bellevue was offering it at around $400. BMW of Seattle wanted at that same time around $1000. No indy shops I could research on the interwebz seemed to be offering the service.
      02-16-2015, 11:38 AM   #16
DustinMN
Our local BMW dealer is doing it for $330 with tax right now.
