      02-08-2015, 06:16 PM   #1
P6
Drives: 1M sold, X5M sold, X6M current
Misc X5M questions
Picked up a new-to-me 2011 X5M a couple weeks ago. Spent some time this weekend detailing, checking fluids, etc. Couple questions.
1. What is this small reservoir in the first pic, just left of the oil filler cap? Is it a secondary coolant tank? Not shown in the manual. Second pic is the coolant overflow tank.
2. Third pic is of my rear tire. 8/32 tread left but inside shoulder is showing increased wear. Both sides are the same. Camber and toe are within spec. Is this a common, expected wear pattern?
3. Guess what I cleaned with this rag? Same color front and back.
4. last pic is of armrest with half cleaned for reference.
      02-08-2015, 07:00 PM   #2
RWilky
RWilky's Avatar
Drives: 2010 X5M
The first pic is for the intercoolers.
I'm going to say no on the tire wear.
And I'm going to guess brake dust on the rag.
      02-08-2015, 07:15 PM   #3
SteveMD
SteveMD's Avatar
196
Drives: 2016 F10 535i MSport
+1. The intercoolers are air to water and have their own coolant reservoir. That is the cap for it.
2006 E90 330i (retired)
2009 E90 335i (retired)
2012 E70 X5 50i M Sport (retired)
2016 F10 535i M Sport
      02-08-2015, 09:11 PM   #4
P6
Thanks. What fluid do you put in the intercooler reservoir? I drew some out to check it and it was blue.
Rag is from the steering wheels? Disgusting.
      02-08-2015, 09:55 PM   #5
RWilky
RWilky's Avatar
Drives: 2010 X5M
Same fluid as the engine coolant.
      02-09-2015, 08:20 AM   #6
PAX5
Drives: 2012 X5 50i
Show us the measurements, and I'll tell you if they are optimized. They may be in spec, but the BMW spec is so w i d e, it will cause abnormal wear as you are experiencing.
PAX5
BMWCCA 20645
      02-09-2015, 10:26 AM   #7
P6
I don't have any current alignment results on a pro rack. I have a toe tool and did a quick measurement in the driveway. Looking at about 1/8" toe in. Eyeballing the camber, it looks like about -2.0. What is the consensus for specs to minimize rear inner tire wear? I suppose I could go down to 1/16 toe in and a little less negative camber in the rear, but I don't want to adversely affect handling. Front is also about 1/8" toe in and tire wear looks fine.
      02-09-2015, 11:47 AM   #8
PAX5
Drives: 2012 X5 50i
Attached are my recommendations: these are optimized for minimal (shoulder) tire wear without a severe compromise in handling and within BMW specs, albeit on the edge for toe-in.
Let me know how it works.
PAX5
BMWCCA 20645
      02-09-2015, 01:00 PM   #9
P6
I'll give those specs a try.
You're probably getting pretty response turn-in with that front toe setting. Do you find it tramlines? I like 0 front toe on my 1M but it will wander a bit more. The X5 is my wife's truck and she would be more interested in straight line stability.
Is there much adjustability in front camber? I can see why people complain about eating front outside shoulders. O camber will do that.
