02-02-2015, 07:36 PM | #1 |
Tanzanite Blue II X5M Pilot
1050
Rep 2,024
Drives: M3, M4, X3 M40i, X5M
X5M rotors and pads?
Does anyone have a good hookup on OEM X5M rotors and pads?
best I have found is $1900 installed.... My rotors on my X5M are beginning to show a lipped edge, but the vehicle still brakes very well... (it's the squeak that is really annoying). Do I just need pads and sensors or is it time for a full brake job? |
02-02-2015, 07:45 PM | #2 |
Rep 129
If the rotors are showing wear, they probably need to be replaced or at the minimum resurfaced. They will need to be checked to see what their thickness is though. That is the key, what the rotor thickness is will determine if they need to be replaced.
02-02-2015, 10:53 PM | #3 |
Rep 139
Not much savings but ECS has them for $ 1745, and free shipping.
https://www.ecstuning.com/BMW-E70-X5...Pads/Checkout/
"An on ramp is a terrible thing to waste"
EuroCharged Tune--QTP 3" Cutouts--V1 Hardwire--K&N Carbon Delete OEM Muffler Mod--(Best Mod Ever) 15mm Front Spacer--20MM Rear Spacer Last edited by WallyM5; 02-03-2015 at 07:12 AM.. |
02-02-2015, 11:47 PM | #4 |
Rep 994
EBC makes a solid rotor that I think is about $250 for the pair (Fronts) and then another $200 for some carbotech performance pads. Beats anything BMW makes.
Centric also makes a rotor (They also own Stoptech and PowerSlot) but I can't find accurate pricing on their rotor, but it shows up as <$100 each... Then you can get whatever pads you want. Sounds like you're getting raped at a dealer, and paying dealer prices? |
02-03-2015, 06:53 AM | #5 |
Rep 40
Seems like most of the parts sites put the parts at around 1700-1800. Your 1900 is dealer installed? I'd say the 100 is worth it to not deal with the hassle and discarding old parts!
02-05-2015, 03:48 PM | #6 |
1050
Rep 2,024
Unfortunately time and convenience often take precedence over scouring around for the best price. After reviewing my options with the shop, I have decided to let them do the entire job with OEM stuff they can get today. The total cost including labor will be around $2000.... this takes a chunk out of the money I had allocated for new shoes, but at least I'll have a piece of mind knowing that I will not have to deal with brakes again for quite awhile.
02-05-2015, 06:35 PM | #7 |
Rep 994
Shame, brakes are typically done in under an hour at least in my garage... I on;y get stuck on rear brake drums that are stuck to the hubs... I save my friends and family thousands of dollars doing their brakes. This kind of work is where shops make much of their money(margin)
02-06-2015, 09:43 PM | #8 | |
Rep 139
EuroCharged Tune--QTP 3" Cutouts--V1 Hardwire--K&N Carbon Delete OEM Muffler Mod--(Best Mod Ever) 15mm Front Spacer--20MM Rear Spacer |
02-07-2015, 12:59 PM | #9 | |
Rep 27
02-07-2015, 06:39 PM | #10 |
Rep 40
02-07-2015, 07:39 PM | #11 |
Rep 139
Correct, $1900.00 installed if you need to replace everything is a excellent price.
