      01-31-2015, 02:29 PM   #1
SB330
Drives: 330
Spare tire size and mounting
So I went from runflat to non-runflat and ordered spare tire kit from getBMWparts.com
but when I brought it to tire shop for mounting and balancing, the tire shop wasn't able to inflate the tire saying the tire is too skinny for the rim.
tire is 155/90D 18 Dunlop.
Did I get incorrect parts? or is there special way to inflate the tire and the shop I went didn't know about it?
I emailed getbmwparts.com and waiting for reply. Called several bmw dealers and all are saying there are no spare tire parts for 2012 x5.
Part #'s are
36116768861 compact spare wheel
36120418845 tire 155/90d18 dunlop
      01-31-2015, 05:07 PM   #2
BeamerandBimmer
Drives: S63tu
Tire size has got to be wrong. That tire looks about the right size for a motorcycle.
Current BMWs;'18 M2, '20 R1250GS Adventure
Past BMWs;'22M850 Conv, '19 SG M5(ED 5/19),14 Ionic Silver i3, '16 S1000XR, '16 Azurite Black M5, '07 G650X-Challenge, '10 R1200GSA, '15 Mineral Gray M4, '14 S1000R,'10 Alpine White 135ia M-Sport, '13 Carbon Black X5 50i, '10 Carbon Black M5, '07 Graphite K1200GT, '08 335ia, '05 545i, '04 R1150R, '03.5 M3 Cabrio, '00 540ia, '97 M3 sedan, '97 540ia
      01-31-2015, 06:25 PM   #3
eswimm
Drives: 2015 i8
X5M spare is 155/80R19, so tire sounds right. Rim might be wrong.
      02-01-2015, 09:55 PM   #4
SB330
Drives: 330
Originally Posted by B_M_W-X6 View Post
Tire and wheel are correct. Place a ratcheting strap tie-down around outer circumference of tire. Tightening of strap causes bead to bulge outward toward lip of rim enabling inflation of tire.
Brilliant!
But would it hold the air or the shape after it is inflated?
I wonder if this is normal, if the dealer stored the tire improperly, or simply another BMW's quirky feature.
I'm gonna try with ratchet strap tomorrow.
      02-02-2015, 04:56 PM   #5
overheadvalve
Drives: 2011 335I Coupe/2017 Macan
I have the same kit in my X5 and my tire and wheel guy got the tire mounted on the space saver rim with the ratcheting strap technique SB330 noted above. It holds air.
      02-07-2015, 07:05 PM   #6
SB330
Drives: 330
It worked like a charm. Ratchet Strap!
Thank you B_M_W-X6
