      09-16-2014, 01:11 AM   #1
JupiterBMW
Self Proclaimed Roundel Junkie
JupiterBMW's Avatar
Drives: '11 E90 M3 & '13 F25 X3
Retrofit Soft Close Doors?
Anyone have any info or experience they could share? This is one option I didn't get in our X, but I'd love to retrofit... Looking on RealOEM, I believe the latch assemblies I need are...
51217315019 Driver
51217315022 Passenger
51227315023 Left Rear
51227315024 Right Rear
Aside from that, I'm sure there's some coding, but I'm unsure if the vehicle is prewired or ready to accept the latch assemblies.
Any help is appreciated...
2018 F15 X5d Carbon Black/Nutmeg Individual- Oil Burner Tow Rig
2013 E82 1M3 Carbon Black/Black- S65/DCT Track Toy
2013 F25 X3 35i Alpine White/Chestnut- German American Family Hauler
Past: '11 E91 335is, '11 E90 M3, '10 X5M, '14 328d, '03 330i Dinan3 ZHP, '04 330i ZHP, '12 X3 35i
      09-16-2014, 03:01 AM   #2
tlovidiu
tlovidiu's Avatar
Romania
Drives: BMW E70 - 2011 - 40d
I am really interested in this too
E70 - 2011 - 40D - Performance Black Grills, OEM 375 Style Wheels, All Front Grills Black, BAVSound Stage 1 Kit, LED stips on front
www.OVILEX.com
      09-17-2014, 07:14 PM   #3
blue dragon
Drives: '22 Tesla MY + '23 Tesla MY
Its been done http://goo.gl/vADPIW
Same procedure.
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
      09-22-2014, 01:07 AM   #4
JupiterBMW
JupiterBMW's Avatar
Thanks, I've already read that procedure, as well as another one here on Bimmerpost (also an E9x). I'm mostly curious if anyone has done this on the E7x chassis and if all of the vehicles are prewired. I'd like to make it as close to OEM as possible, adding the option to the VO and then coding all the necessary lines to activate it.
My two biggest question are whether the doors are built for a direct, OEM bolt in and if the doors are prewired...
Can anyone answer those questions? Has anyone had the door cards off? Maybe a couple pics?
      09-22-2014, 11:17 AM   #5
smyles
Drives: '21 X5
Just a guess, but even if, say, my X5 is prewired doesn't mean your's is. BMW changes it over the model run, plus different trims/markets/etc may cause variance.
Also, if you do get the retrofit done, watch your and especially your kids' (if any) fingers.
      09-22-2014, 01:05 PM   #6
JupiterBMW
JupiterBMW's Avatar
Yeah of course. I found that in my E46, most everything was prewired across the board, and to be honest, it makes a lot of sense when it comes to production costs.
I have read a couple of stories about finger pinches too, but thanks for the heads up. We do have 2 small kids, too small to get in and out by themselves though, so we would have a few years before we have to worry about that... It is a concern though. Perhaps just on the front two doors... Still have to even look into the doors of my X when I can (I'm out of the country for work for 2 months, so just doing some research and getting ideas). Also have to find out cost when I'm home.
      09-23-2014, 09:00 PM   #7
iDido
Drives: 2012 BMW X5
Can sombady provide part number for the wire harness or the soft door connector's part number and fuse numbers?
      09-24-2014, 01:52 AM   #8
JupiterBMW
JupiterBMW's Avatar
The closer mechanism part numbers are above.
      09-24-2014, 02:06 AM   #9
iDido
Drives: 2012 BMW X5
To the parts above you will need an original wire harness or you have to use at list original connectors and run wires to the fuse box and connect wires there.
I am asking about this part numbers.
      10-01-2014, 04:52 PM   #10
xpl0sive
Drives: bmw
this is sort of related. my car was in an accident on passenger rear before i bought it. It has the soft close door option. all other doors work fine. the passenger rear door, the soft close does not work like it's supposed to. when the door isn't shut completely, it will not pull the door in. but when you shut the door all the way, the mechanism pulls it in further and then back out like it's supposed to. it seems that it just wasn't adjusted properly. does anyone know how to adjust the latch so it works correctly?
      10-02-2014, 12:25 PM   #11
SchaumerMol
SchaumerMol's Avatar
Drives: 2020 X7 M50
Try moving the striker bar a bit, that's the silver part the door latches to.
I think it is a Torx T40.
Google for the adjustment procedure (it is, it is very easy and not time consuming, but mark the current position, so you can go back to where it is right now.
A little movement goes a long way...
Here some info:
http://www.m5board.com/vbulletin/e39...nute-less.html
      10-02-2014, 03:11 PM   #12
JupiterBMW
JupiterBMW's Avatar
Can anyone tell me, when did the soft-close doors even become available on the E70s??
      10-02-2014, 05:50 PM   #13
jiggz
Drives: E90 M3|F15 X5 50i
Based on what I've read it depends on the country and/or model.
In the U.S. (perhaps all of North America?):
-1st available as an option in 2010 on the X5M only
-For non-M's, available in 2013 only
--$600 option on the 50i & 35d
--Part of the Convenience Package on the 35i
*I feel like I've seen it, maybe, on a few 2012's while I was searching for mine. If so, I'm guessing it was a later addition/option, like the paddles were on late 2012's. Not positive on this.
Non U.S. - looks like it was available from the beginning of E70 production in many countries.
      10-03-2014, 10:48 AM   #14
JupiterBMW
JupiterBMW's Avatar
Awesome thanks man, that makes me happy, I'm hoping I'm at least prewired for the option. Would probably make the retrofit a lot easier.
      10-05-2014, 11:23 PM   #15
jiggz
I'm not really seeing the benefit/desire of this option. Who here has soft close doors, and do you like them/feel like they're worth it? So you don't close your door with enough muscle and this option basally sucks the door closed….how often does that happen? If you close the door properly…
      10-05-2014, 11:55 PM   #16
JupiterBMW
JupiterBMW's Avatar
For me it's not about not using enough muscle, it's just a matter of gently pulling the door closed enough for the first click and the letting the mechanism take over. It's easier on the car as we know the E70 interior makes a lot of noise. I'm trying to not have any more squeaks and creaks than I need to. Besides, I just think it's cool. ðŸ˜
      10-06-2014, 01:03 PM   #17
xpl0sive
Drives: bmw
my 2008 has soft close doors so that was the first year they were avaliable. I love the option, you don't have to slam the door at all, most of the time i just give it a gentle tug and it closes on it's own.
by the way, i tried adjusting the striker bar and that didn't help. i think it's the actual lock mechanism that needs to be adjusted somehow
      10-06-2014, 03:26 PM   #18
blue dragon
It was available in Canada
      10-06-2014, 07:31 PM   #19
iDido
Drives: 2012 BMW X5
@ xpl0sive
Can you please check at "http://www.realoem.com/bmw/select.do" what is part number for your wire harness or the 2 pin plug. Front door only is OK. Thank you.
My 2012 X5 it's not prewired for soft door closing and I'm interested doing this retrofit.
      10-06-2014, 09:31 PM   #20
jspdr
Drives: X5
I had it on my 535 m sport. Yes, its cool to show someone how it works, or talk about it, but it is a worthless option for me.
      10-06-2014, 10:50 PM   #21
JupiterBMW
JupiterBMW's Avatar
Great feedback, thanks... So we've got a 2008 with the option, but a 2012 X5 that is apparently not prewired. It would be nice to get everything sorted so that it'd be easier for others to do the retrofit in the future.
      10-07-2014, 12:38 AM   #22
jiggz
Jon, it seems U.S. and Canadian vehicles are different. We've got Canadian members saying their 2008 has it, and I've read in other threads/other forums the same thing from European owners. However, I have yet to read/see/hear from an owner in the U.S. that says they have this option unless they have a 2013 non M, or 2010 X5M (and again, optional equipment in both cases).
If someone can prove me wrong I'm totally cool with it - just haven't seen, read, or heard anything in that regard. I just ran a 2010 X5M VIN the other day and saw it had soft close doors, so I know it was available in 2010 on the X5M in the U.S. And it's was actually a pretty common option on the 2013 50i VINs I was running a few months back before I bought my current X5.
