      06-01-2016, 02:54 AM   #1
titanle
titanle's Avatar
Drives: 2010 X6 Activehybrid
Exhaust valve vacuum lines
Quick question guys,
I did the zip tie exhaust valve bypass mod today and I wanted to know whether its imperative that I disconnect and plug the vacuum lines. Right now they are still connected to the exhaust valve.
      06-01-2016, 03:17 PM   #2
titanle
titanle's Avatar
Heres a link showing cold start and idle with the exhaust valve bypass mod done. It sounds deeper and throatier at idle. There are also some nice backfires/crackles when revving above 3K rpm.
      06-02-2016, 04:23 AM   #3
peter2772000
Drives: 2012 X6 35i Sport
This is one of the 1st mods I'm doing when I get back down to the Cape. And, I will definitely be disconnecting/plugging the line and the vacuum port on the exhaust valve to prevent debris from getting in there.
I'm curious to see if I get any drone at lower highway speeds though...
      06-02-2016, 11:28 AM   #4
titanle
titanle's Avatar
I haven't noticed much drone so far.
      06-02-2016, 01:55 PM   #5
omgboost
Drives: 2012 X5 35i
What does the vacuum line do, if I just unplugged it without ziptieing the flap open?
      06-02-2016, 03:31 PM   #6
titanle
titanle's Avatar
from what I've gathered, the vacuum lines keep the flap closed until enough pressure builds up (WOT) allowing the flap to open.
In my X6 removing just the lines does nothing. The flap mechanism itself needs to be zip tied or wired in the open position, otherwise once you let go it springs back to closed position.
      06-03-2016, 08:08 AM   #7
omgboost
Drives: 2012 X5 35i
That's the same way it works on my X5. I had ziptied mine without disconnecting the vacuum lines. I'm thinking maybe the lines help keep it open after a certain RPM in ours because the mechanism stays closed by default.
      06-03-2016, 02:28 PM   #8
titanle
titanle's Avatar
I think thats correct. Its a neat little mod, I got that little extra oomph in the exhaust note that i was looking for without it being overbearing.
      06-06-2016, 03:32 AM   #9
peter2772000
Still no noticeable drone? If you're going to get it, it's typically at the lower end of cruising speeds, 45-55 mph.
      06-06-2016, 12:58 PM   #10
titanle
titanle's Avatar
Maybe I lucked out, but i haven't really noticed any drone with this mod.
      06-06-2016, 01:48 PM   #11
denaliman
denaliman's Avatar
Drives: 2021 BMW X6M Competition
2013 X6M  [0.00]
If you just unplug it without capping the line you will get a error message I believe.
_____________________________________
2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4
      06-06-2016, 06:10 PM   #12
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
The vacuum line runs from the engine bay all the way to the trunk, tees into a sensor and then vacuum lines run to the valves. Leave any of those unplugged and you'll notice an instant decrease in power. I kept having reduced power warnings (found out it's a different issue), but had assumed my exhaust lines we're capped properly. For anyone who wants to test it, unplug a vacuum line from one of the vacuum canisters in the engine bay, drive away and it'll feel like you don't even have twin turbos.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      06-07-2016, 01:22 AM   #13
titanle
titanle's Avatar
I just left the vacuum lines plugged into the valves and zip tied the exhaust flaps themselves in the open position. No error codes, no loss of performance, great new exhaust note.
      10-30-2017, 03:35 AM   #14
peter2772000
Forgot to post back. Did this last year and no drone whatsoever. Gnarly exhaust note on a cold start.
Well, as gnarly a note as one can expect on a straight 6 LOL.
2007 FJ Cruiser
2012 X6 35i
2013 ML350 BT
2019 4Runner
