      06-15-2014, 12:57 PM   #1
Auto
Sweden
170
Drives: MB CLS 63 AMG
Hub thread damaged with wrong bolts! Need new hubs!
I messed up my wheel hub thread by using wrong bolts.
I need to replace the hubs and this time use the right bolts.
Does anyone know where I can find the parts and a DIY to change them?
      06-15-2014, 06:10 PM   #2
jadnashuanh
Drives: 535iGT x-drive; i3 BEV
I would think that a helicoil could restore the hub to a usable fashion without replacement and may be quite a bit less expensive than replacing it with new ones. Not sure what hubs cost - labor to repair the holes with helicoils, if you can't do that yourself, may make just replacing the whole thing cheaper.
      06-15-2014, 07:37 PM   #3
PrimoM3
Chemofski
PrimoM3's Avatar
Drives: '13 X5M
For safety and peace of mind, I would just replace the hubs. Good luck.
'13 Individual Frozen Brilliant White ///M3 Coupe
Ordered 2/15/12 | Euro Delivery on 9/21/12 | U.S. Redelivery on 12/6/12 | Motor Dead on 7/15/13
'13 Space Gray/Mugello Red X5///M
Pavement Punisher | Snow Muncher | Family and Board Hauler | Roadtripper
      06-15-2014, 10:12 PM   #4
joe_planet
Drives: 2011 X5d
Replacing hubs is pretty straightforward. Take it apart and swap them out. Make sure to get an alignment afterwards if youve taken apart enough suspension bits
      06-15-2014, 10:15 PM   #5
mitch808
Drives: 2012 X5 35i
You don't want a helicoil, you want to use a time-sert or bigsert. When done properly it'll match the torque rating of the factory lug nuts.
      06-15-2014, 11:45 PM   #6
Auto
Sweden
170
It's a powerful car and I think the best thing to do would be to replace the hubs.
Does anyone know where I can order them cheap and i DIY?
Thanks!
      06-21-2014, 06:42 AM   #7
hd2000fxdl
Drives: 2011 X5
Glad I read down before posting, yes time-serts are a lot nicer than helicoils.
To the OP, is this just 1 bolt, or did you do all 5?? Just wondering?
Harry
