      06-05-2014, 12:21 PM   #1
W84IT
Drives: 640i Gran Coupe M Sport
Wheel Spacers...
I called Turner Motorsports to order wheel spacers for my X5 and was informed that they will need me to check the size of the hub bore because some of X5's and X6's have 74.1mm and some have 72.56mm hub bore. Can anyone with a 2011 xDrive 5.0i with wheels spacers confirm what set up you have?
Is there any way for me to know without pulling my wheels off to measure?
I want the 15mm front and 20mm rear spacers with 20" style 333M wheels...
      06-05-2014, 12:33 PM   #2
Z@T
Pilot
Z@T's Avatar
Drives: M3, Vantage, 997, ModelX
"Normal" e70 and e71 have 74.1mm hub on all axles.
X5m and X6m have 72.56mm in the rear while 74.1mm in the front.
      06-05-2014, 12:36 PM   #3
upstate650
upstate650's Avatar
Drives: 2014 650xi Gran Coupe Msport
2020 BMW M340xi  [0.00]
I believe all x6 models have 72.56 rear hubs.
2014 BMW 650xi Gran Coupe Msport Black Sapphire Metallic on full black merino leather. 20" M5 343M wheels for summer, 20" 373 wheels for winter with Nokian Hakkapeliitta 8 studded snow tires. M6 CP exhaust with M6 Diffuser and ///M Performance carbon fiber finisher. Mission Performance stage 1.5 and transmission tune.
      06-05-2014, 12:52 PM   #4
W84IT
When you say "Normal" is the 5.0i M Sport considered normal?
      06-05-2014, 01:05 PM   #5
upstate650
upstate650's Avatar
yes - all x5's except the M are 74.1 hubs at all 4 corners.
      06-05-2014, 01:15 PM   #6
Z@T
Pilot
Z@T's Avatar
Sorry if I was mistaken.
Learned something today.
      06-14-2014, 06:21 PM   #7
W84IT
I got the spacers installed yesterday...looks much better!
      06-14-2014, 06:24 PM   #8
W84IT
Another pic...
      06-14-2014, 10:27 PM   #9
Snypa
Drives: Like a mahdman !
Looks Clean !
SUPER SLOW E90
      06-14-2014, 10:42 PM   #10
W84IT
Originally Posted by Snypa View Post
Looks Clean !
Thanks! I just had it washed after installing the spacers and a set of performance ceramic brake pads...low dust!
      06-15-2014, 02:44 AM   #11
mitch808
Drives: 2012 X5 35i
Performance and ceramic should not be used in the same sentence. Its a contradiction of terms.
Pads either stop really well and will dust and/or squeal. Or they are low dust/low-no squeal, and have no performance characteristics. Fact of life.
      06-15-2014, 06:19 AM   #12
W84IT
Tell that to Hawk Performance...
http://www.hawkperformance.com/performance
      06-15-2014, 01:04 PM   #13
mitch808
Drives: 2012 X5 35i
So you succumbed to their marketing basically? It is the holy grail to have performance and low dust. Ceramic pads of any type are not a performance pad, no matter the manufacturer. I would take them over stock OE BMW pads any day though as those pads dust like some of my race pads do.
      06-15-2014, 02:12 PM   #14
W84IT
No, I didn't succumb to anything...I know exactly what I wanted and I'm totally aware of the difference between ceramic brake pads and semi-metallic...I wanted a low dust brake pad and "HAWK PERFORMANCE CERAMIC BRAKE PADS" just happened to be the name of the pads that I purchased.
      06-16-2014, 05:58 AM   #15
SchaumerMol
SchaumerMol's Avatar
Drives: 2020 X7 M50
So what spacers did you get? What hub size?
I have the x5 w/ M Sports Package as well. What hub size does that have?
The one of the normal x5 or the one of the x5m/x6m?
Thanks in advance
Nevermind:
      06-16-2014, 06:50 AM   #16
W84IT
Thanks in advance
Nevermind:
I got the H&R Spacers...15mm front and 20mm rear...both front and rear are 74.1 hub bore...the lug bolts are 43mm front and 50mm rear
      06-16-2014, 09:10 AM   #17
Z@T
Pilot
Z@T's Avatar
Looks better!
Do you have the 15mm already installed when you took the picture?
      06-16-2014, 10:30 AM   #18
W84IT
Looks better!
Yes...the 15mm seems perfect for the front but the rear looks slightly tucked from certain angles...I'm thinking I should have got the 25mm rear instead of the 20mm...I can live with the 20mm rear though because the overall stance has improved.
      06-16-2014, 02:23 PM   #19
Z@T
Pilot
Z@T's Avatar
Great! My 15mm are out for delivery today.
The 25mm are perfect in the rear.
Have them now installed for a month.
      06-16-2014, 02:32 PM   #20
windsailor
windsailor's Avatar
Drives: 2013 X5M Black Saphire
I'm with you, got the 25mm installed and can't be happier!
      06-18-2014, 04:56 AM   #21
W84IT
I might eventually get the 25mm rear...I have noticed that the people with the Dunlop RFT's on seems more flush with 20mm rear...I have the Nitto Motivo tires and they don't have that block look like the RFT's
      06-27-2014, 09:01 PM   #22
Diesel X5
Diesel X5's Avatar
Drives: X5 35d X
I ordered the 25mm H&R about two weeks ago and still waiting for them to come in. I will be just putting them on the rears and leaving the front stock.
