06-02-2014, 07:19 PM | #1 |
Patriot
Rep 71
Spacers and hub size
Hello all,
I'm looking to put spacers on my X, I've got OEM 19"s, not lowered. I have been told that with my M Sport my front and rear hubs may be different, they are different on the M's. Any recommendation on spacer and hub size, I'd most likely go with 12mm on the front and 20mm on the back. Thanks. |
06-03-2014, 04:17 PM | #2 |
Rep 57
Msport isn't an M.
74.1 is your front and rear hub. 15MM front and 20MM rear are a perfect flush fit on an Msport with OEM 20's. I run those and wouldn't change them one bit. |
06-03-2014, 04:18 PM | #3 | |
Rep 3,995
I had to bore out the rear hubs of my M wheels to fit on my M Sport. http://www.xbimmers.com/forums/showthread.php?t=980938
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic |
06-03-2014, 06:10 PM | #4 |
Rep 87
Can't comment on Hub fitment, but I'll say for spacer size, I'd always measure and see what I need for what you're trying to achieve rather than relying on someone on the internet telling you what size to use..
Harry |
06-03-2014, 06:23 PM | #5 |
Patriot
Rep 71
Thanks Dustin, I am fully aware that an M sport isn't an M, love the look but didn't have the additional 30k just lying around. I've been told that my hub size is the same as an M from ECS and Turner, 74mm front and 72.5 rear. I took measurements of my wheels/fender gap and what I came up with is 3/4 front and 7/8 rear which puts me in the 12mm F and 20mm R zone. Just wanted to confirm that fact from our knowledgeable friends. BTW I've got 245's in the front and 285's in the back on 19's
06-25-2014, 11:08 AM | #7 | |
Rep 139
Any other input is appreciated.
2014 Cayenne GTS
2009 C4S Cab 2004 Dodge Viper 2020 M8comp |
06-25-2014, 11:30 AM | #8 | |
Rep 3,995
