      05-11-2014, 08:25 AM   #1
Auto
Sweden
169
Drives: MB CLS 63 AMG
Question X5M hesitates when starting?!
I have a X5M from 2010, 18' miles. When starting the car it hesitates for 2-3 sec and then starts. Sometimes it starts as soon as I push the start button but most of the time it takes 2-3 sec for it to start.
What could this be? Any known issues on the X5M?
When up and running the cars goes with any problems. Just the start issue.
Thanks!
      05-11-2014, 11:26 AM   #2
x5joe2013
x5joe2013's Avatar
Drives: 2013 X5 50i
My educated guess from reading on this forum is injector issue.
Do a search for injectors or black soot and you should find quite a few threads describing long cranking at cold start.
      05-11-2014, 12:54 PM   #3
RichardH
RichardH's Avatar
South Africa
27
Drives: X5M
I am having a similar issue. Leaning towards to a faulty starter. Also no other issues when driving. Also does it at anytime time of day.
      05-11-2014, 06:37 PM   #4
upstate650
upstate650's Avatar
Drives: 2014 650xi Gran Coupe Msport
2020 BMW M340xi  [0.00]
Thanks!
2-3 seconds for start is normal. Longer than 5 is when you should suspect injector issues.
2014 BMW 650xi Gran Coupe Msport Black Sapphire Metallic on full black merino leather. 20" M5 343M wheels for summer, 20" 373 wheels for winter with Nokian Hakkapeliitta 8 studded snow tires. M6 CP exhaust with M6 Diffuser and ///M Performance carbon fiber finisher. Mission Performance stage 1.5 and transmission tune.
      05-13-2014, 10:56 AM   #5
eswimm
Drives: 2015 i8
Thanks!
For me it was injectors. Cold starts were fine, but if the car sat for 2-4 hours, the start was horrible. It got progressively worse and I started getting smoke under very hard acceleration.
Finally brought it in and dealer said 3 injectors were faulty. CarMax warranty was going to cover the 3 injectors, but BMW replaced all 8 and plugs under goodwill. 2010 X5M w/ 52k miles.
      05-13-2014, 03:27 PM   #6
Jimshorts
Jimshorts's Avatar
19
Drives: x5m
Sounds normal to me.
2010 BMW X5 M Eurocharged: 12.298 @ 112.860 MPH Tune only.
2005 E55 AMG 11.93 @ 117 1/4 mile 7.75 @ 95 1/8mile tune, shorties, street tires. Sold
      05-14-2014, 10:26 AM   #7
BMW_Diesel_Owner
Drives: 2009 BMW X5 xDrive35d
This may sound off tangent, but I had a similar issue with my Diesel X5 a few weeks back. Anyway, the issue went away after I charged my battery. I understand that we are talking apples and oranges here, but check to make sure that your battery is charged up.
I used a Noco G7200, and it was amazing!
      06-28-2014, 09:37 AM   #8
mweisdorfer
mweisdorfer's Avatar
Drives: 2007 Black/Black 335i e90
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
If I had to start somewhere, I would start by changing out the plugs and coils as well as cleaning the Mass Air Flow Sensor. If still an issue, then I would run back to back fill ups with techtron followed up by cleaning the throttle body out with some intake cleaner and a small, wire brush. I would then be doing a sea foam via the brake vacuum line smoke show. If still doing hesitation after start up? I dont know.... Maybe change out the MAF?
