      08-20-2013, 02:51 PM   #1
RyBMW
RyBMW's Avatar
78
Drives: X5
2012 BMW X5  [0.00]
2008 335i  [0.00]
Strange noise in the front
Just recently I have been hearing this strange rubbing or knocking sound from the front of the car. It's very low and I only hear it when the car has warmed up after a few miles of driving and only when going over bumps under 20MPH. If I have the music on I can't hear it. Suspension feels normal. Sometimes I hear it only from the passenger side and sometimes only from the driver side. I did notice the spring pad is sort of rubbing on the spring. Picture attached.
Any ideas?
New: 12 X5 xDrive35i Premium Alpine White/Cinn Brown
Old: 08 E92 335i|Space Gray/Coral Red/Gray Poplar
Old: 06 E90 330i|Black Sapphire/Black /Burl
      08-22-2013, 11:12 AM   #2
3s-a-charm
3s-a-charm's Avatar
Drives: 2017 Tesla Model X
2007 BMW X5  [0.00]
Is it more of a rub or clunk? I had a clunking coming from my 07 X5 and just had the Active Sway Bar replaced which fixed it (not cheap, though).
17 Tesla Model X 90D (I've been converted!)
PAST: 14 Tesla Model S P85D, 16 X1, 13 X5 M-sport, 04 M3 Cab, 08 E92 M3, 08 535xiT, 07 X5 4.8i, 06 E90 325i, 87 E30 325i, 85 E30 318i
      08-22-2013, 11:45 AM   #3
rennis
rennis's Avatar
43
Drives: E70 5.0 & B5 S4
Have you had any work done on the truck recently? Had a similar noise in the wife's M3 after a coilover install. The strut bearing fasteners on the shock tower were not properly torqued.
      08-23-2013, 12:52 PM   #4
RyBMW
RyBMW's Avatar
78
Drives: X5
2012 BMW X5  [0.00]
2008 335i  [0.00]
No work done. Very low clunk/knocking sound. Only when the truck is hot and driving under 20MPH. Sometimes only on passenger side and sometimes only on driver side.
      09-18-2013, 10:46 AM   #5
RyBMW
RyBMW's Avatar
78
Drives: X5
2012 BMW X5  [0.00]
2008 335i  [0.00]
My car only has 11K miles now. The chances that it's the suspension should be pretty low. I'm thinking it may be a rattle from something lose. Engine cover? It only occurs when the car heats up.
      09-18-2013, 01:31 PM   #6
Spaceballs
Spaceballs's Avatar
Drives: 2010 Space Grey X5M
I had my sway bar links wear out in 2+ years, and BMW stated that was normal wear and tear. Hmmmm...
Sounded like a low muffled clunk. Happened more on rutted roads than on potholes. I found it by putting it on a lift and moving the sway bar ends.
'10 Space Gray, Cinn Int.
      10-11-2013, 09:14 AM   #7
RyBMW
RyBMW's Avatar
78
Drives: X5
2012 BMW X5  [0.00]
2008 335i  [0.00]
How much was it to replace?
      10-13-2013, 09:23 AM   #8
Mamba003
Drives: 2010 X5M
Had a rattling noise recently with similar characteristics of what you discribe. Took the tire off and didnt see anything obvious but the swaybar end link would shift when I pulled on it but was loaded since only one side was in the air. Took it in and they confirmed it was the endlink. Replaced under warranty and no more noise. Truck about ride better and much quieter.
      10-13-2013, 11:59 AM   #9
3s-a-charm
3s-a-charm's Avatar
2007 BMW X5  [0.00]
Mine was about $3,800 to replace but rides like a dream now
      10-15-2013, 10:26 AM   #10
RyBMW
RyBMW's Avatar
78
Drives: X5
2012 BMW X5  [0.00]
2008 335i  [0.00]
I'm starting to think it's sway bar end links, drop links, or tie rods.
      10-15-2013, 01:40 PM   #11
Spaceballs
Spaceballs's Avatar
How many miles were on it at the time, and what type of warranty coverage-new car, cpo, or extended?
      06-20-2014, 02:55 PM   #12
RyBMW
RyBMW's Avatar
78
Drives: X5
2012 BMW X5  [0.00]
2008 335i  [0.00]
I dropped my car off at the dealer this morning for this and other maintenace. Got a call from my SA that he test drove it and did not hear anything out of the ordinary. The techs even checked the whole front suspension and did not see anything wrong. They tell me that it's the control arm bushings and sometimes it normal for it to make this noise. He tells me that there is a new M5 on the lot with 5miles and it also make this noise.
Normal? I'm thinking i'll take it to another dealer to verify.
      06-20-2014, 05:13 PM   #13
Bklynjoker
Bklynjoker's Avatar
85
Drives: G20 %E2%80%9C22%E2%80%9D MSpor
AwwMan... I'm dealing with that same jiggle sound left front wheel.
My experience: I've had a "03" s430 -GREAT MOTOR & TRANS. But when it came to electric,airmatic,ball joint,control arm,cluster. The car was a complete nightmare.
I just got a CPO "11" 2months ago and under 20mph I'm having flashbacks of my S430. Mine sounds like some sort or bushing or ball joint. Reason under 20mph is function of shocks. Once it builds speed & movement shocks become stiffer. Off redlight/stop sign the shocks aren't bouncing/moving to create stability.
If you able to jack the x5 up grab the wheel and try to jiggle left&right or pull/push. If u have movement then something is getting worn. Bushing or joints
      06-13-2016, 12:19 AM   #14
ashawkys
ashawkys's Avatar
Drives: e70 x5 4.8i N62/ e92 335xi N55
did you replace the whole active sway or what? what cost 3800 exactly haha? thanks
      06-13-2016, 06:56 AM   #15
3s-a-charm
3s-a-charm's Avatar
2007 BMW X5  [0.00]
Well that was a long time ago but I recall being on vacation (road trip) and getting an error message that sounded like a safety concern with the steering (can't recall the wording). I took the truck to BMW who said what needed to be replaced and I did it. That made for an expensive road trip...
Not sure what was replaced to be honest.
      06-13-2016, 10:12 AM   #16
ksa
ksa's Avatar
Drives: Aston Martin Vantage & others
I wonder if this is the same as the rapid clicking noise I hear after the car is turned off. Almost like a fan noise but it goes on for long after the fans have turned off as well. It's super annoying.
      06-13-2016, 12:16 PM   #17
heatmizr
Drives: E70 X5 50i M-Sport
Well since he said he hears it driving over bumps on warmed up engine, and yours is after you shut the car off... then No.
heatmizr [Todd]
g26 i4 e40 - Clean Machine
e90 328i - sold
