Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > X5 Vendors Classifieds
      09-15-2016, 03:06 PM   #1
Sales@RKautowerks
Sales@RKautowerks's Avatar
357
Drives: e92 m3
RK Autowerks X5M intakes group buy
Hey guys,
We've been working on these intakes the last month and finally dyno tested them today in their prototype phase.
We 3d scanned a stop vehicle to get all the dimension as you see below, design our intakes, test fit them, road tested them, and dyno tested them.
If there is enough interest in something like this, we will have these made in carbon fiber like all our other products. Due to forum rules, we will create a thread in the for sale section for a potential group buy.
To push these to the final phase, we're looking to start a group buy.
MSRP would be $1600
Group buy of 5 people, $1300 to make this product come to life.
Final product would be in carbon fiber.
To sign up for the product, a $250 deposit is necessary.
Here are some images of what to expect in terms of final quality.
For more of our work, you can check out our M3/M4 development.
http://f80.bimmerpost.com/forums/sho....php?t=1303768
Thanks
-R
      09-15-2016, 03:21 PM   #2
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
The ///M tax is still alive and well...
Just like exhaust, I'm curious if the changes in diameter from big to tight would be detrimental to airflow vs making it all one overall diameter that matches that of the turbo inlet pipes you're connecting to. Granted mine goes from oval to round like yours since the crossbar above the radiator gives us no choice, but at least mine stays a consistent diameter.
TTV8M122.50
      09-16-2016, 09:30 AM   #3
Sales@RKautowerks
357
Drives: e92 m3
Doesn't make a difference with the diameter, you want it to be large as possible to reduce the frictional losses associated with the flow.
-R
      09-16-2016, 10:02 AM   #4
protecon
*May contain nuts
protecon's Avatar
Australia
193
Drives: 2010 X5M MCB
There's negligible drop on intake as it's all negative pressure. I'd be more concerned on getting every psi generated by the turbo to the intake manifold as cold and compressed as possible, rather than spending money on what is essentially overcomplicated CAI that usually best fits NA motors.
The only reason you're seeing flow (and potentially power) increase is because you've reduced the volume of filter.
      09-16-2016, 10:12 AM   #5
Sales@RKautowerks
357
Drives: e92 m3
Not exactly true, the benefit is from reducing the pumping loss.
Here's a more thorough explanation with data conducted on the F10 M5.
Originally Posted by Raza@RKautowerks View Post
Hey guys!
I've been working on these intakes the last couple of months, done a lot of testing and finally got the first pieces in today!
The intakes were produced using state of the art methods from start to end.
1) 3d scanned stock airboxes to ensure fitment is like a glove.
2) 3d scanning ensure the MAF calibration is not tampered with.
3) CFD to ensure the flow was optimized and nothing left on the table.
4) 3d printed to check fitment, flow tested, dyno tested.
5) CNC carbon fiber molds
6) Autoclave carbon fiber production
I'm going to reserve some space for dyno results, i have the prototype intakes dynos, we were hitting abotu 600-625whp with a tune and downpipes. But that's not a final number by any means, the testing was more durability and heat soak, not numbers.
Even then, i feel the flow numbers are what you guys should focus on, well not just flow number but flow numbers as a function of delta pressure. So i'll give you guys a brief explanation on how intakes actually "make" power as you guys like to put it.
I'm sure you've heard that intakes make power, that's a not exactly true, intakes don't make power at all. They FREE up power, the engine is already producing what it can produce at its RON(gasoline) knock limit provided a chain of other criteria are not holding it back. As an OEM(i work for an OEM) we design intakes very differently than the aftermarket, we have noise, vibration, power constraints, costs, and durability in mind. A combination of these constraints are why we leave "power" on the table. In the aftermarket the consumers are usually power and aesthetics drive, not so much concerned about the other constraints.
So with that said, the intake system is purposely constrained from factory. The ECU is calibrated with the intake system and it's shipped off.
So how do you "free" up this power?
The common assumption is that your intakes make power, false. The governing equation/theory/facts behind this is BMEP = IMEP + PMEP + FMEP. Where BMEP is the brake power, the power the engine will produce at the crank rather. Now you have IMEP, the indicated mean effective pressure, the power loop of the PV diagram. This is where the magic happens, IMEP is the boom inside the engine, the working portion of the PV diagram. This is the absolute amount of power the engine can make before it starts sending the power in all sorts of direction. PMEP is where the intakes come in, PMEP is the pumping mean effective pressure. The engine has to utilize some of its IMEP to suck in the air and push the air out, this isn't free after-all. Then you have FMEP, the friction portion of the game, this is your rotating assembly, lubrication, seals, and etc.
Here's a PV diagram to visualize what's going on.
BMEP = crank power = measured using a dyno
IMEP = power loop = measured using in cylinder pressure transducers
PMEP = pumping loop = measured using in cylinder pressure transducers
FMEP = friction = calculated using math by knowing BMEP/IMEP/PMEP
So now that we've established power is only made in the power loop, everyone should be onboard with why intakes don't make power.
Intakes are like straws, us as a humans can suck in x amount of water using a straw that is half an inch wide, we can also suck x amount of water with a straw that is 4x as small. It's easier to drink through the bigger straw right? Same concept with an intake! Which brings me to my next point, an efficient intake is like a big straw, really easy to suck the water through. We call this value "delta pressure" the amount of suction needed to move a certain amount of fluid through a vessel.
With that said, you want to make it easy for the engine to "breath" on a forced induction application, easier for the engine to breath means less power it has to use to suck that air. See where this is going?
Lets put some numbers with our equations.
(end power) = (total power) + (pumping loss) + (friction loss)
10 = 14 + (-2) + (-2)
That is configuration A
now we have our new intake, configuration B, the big straw
11 = 14 + (-1) + (-2)
You just increased the crank power of the engine, by freeing up power that was always there! This is why when you see flow in LPS, it doesn't hold much value, so you increased the flow? Does it mean anything, because the flow has to have some type of delta pressure associated with it, how much suction did you need to produce that flow. I can take a 2" pipe and flow 500LPS through it, but i had to have a ton of suction on it. But my 3" pipe only flowed 300LPS, but it was barely sucking. Marketing will make you think the 500LPS is better because well...you didn't know, now you do!
With that said, i ran the flow numbers and will demonstrate why our intakes will produce an increase in power.
This graph shows the amount of air an engine is consuming based on your boost pressure (turbo application only). This gives you an idea of how much air your engine is consuming at wide open throttle at a certain RPM.
Now you have what most are used to seeing, the "flow increase" diagram. I have my X axis as a function of delta pressure, which is what you should ask for. But like we discussed earlier, this doesn't help quantify why engine is making more power. You see that you increased flow at each delta pressure, but you don't know what the delta pressure drop is, just what you increased flow by.
This is why you should ask the vendor for this graph. A chart of delta pressure as a function of flow. Now you can quantify, based off how an engine works as explained above, what benefits to expect to see. You can see for yourself in the chart below how this compares. Referencing to my cylinder head flow chart and comparing what delta pressure benefit you have based off the RPM at WOT condition. You can see below how my intakes compare to a competitor and how they compare to stock. I've reduced your pumping loss up to 40-60%, power you were allocating to move the air into the engine before, is now being used to move your car! The lower your delta pressure, the better.
Reason why i bring that up is because it's really easy to quantify the difference between intakes when you conduct testing using a flow bench. It's not easy to compare intakes or really quantify power differences on a chassis dyno because you have so much going on that needs to be accounted for. You need a bench dyno running some state of the art equipment to truly quantify it, stuff i do at work. The flow bench is something anyone who's charging someone several hundreds for an intake should use to validate their product. You can make this entire system go full circle and derive a correlation between delta_P reduction and the pumping loss benefit if you had a system sophisticated enough to accurately capture the PMEP inside the engine. Then you could back out the increase in power as a function of Delta_P. You'll be hard pressed to find shops outside the OEM that have this capability, i know of a handful. Happy modding!
      09-16-2016, 01:45 PM   #6
m5james
m5james's Avatar
You're citing the extensive research you did on the M5 intake, but did you do the EXACT same research with this intake or are you assuming a one size fits all approach while charging near M5 prices without as much design time?
      09-16-2016, 02:12 PM   #7
Sales@RKautowerks
357
Drives: e92 m3
Did you even take the time to read what i said? The member asked why and how intakes make power, i just explained it. Only thing that is going to change is the flow numbers. But since this time around i have the delta increase in power before flowing, i can work backwards.
If you'd like to understand that, read the post.
Thanks
-R
      10-01-2016, 07:44 PM   #8
39nas-t
Work Smarter!
39nas-t's Avatar
Drives: TBSS, X5M(Wife's)
I'm Interested
      10-26-2016, 03:23 AM   #9
m5james
m5james's Avatar
How are these coming along? Buyers, any updates and input? It's been discussed on the GroupMe app that it'd be nice to have a simpler plastic version made, maybe a price point around $600, then more would jump on of these haven't taken off as planned. Although mine are stainless steel and are a one off, I'm glad I got them as to this day they're still awesome to hear :-)
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      10-26-2016, 10:20 AM   #10
Sales@RKautowerks
357
Drives: e92 m3
Mold design is being finalized, an F1 team needed a full chassis built in carbon which has delayed our production heavily, or these would have been done weeks ago.
No plastic version will be made, the amount it costs for tooling would outweigh any benefits. Plastic is only worth it if there is very high volume involved.
The rapid prototype which a member has been running cost me more than 600, so that will not be an option either.
Hopefully i have the first set mid November.
Thanks
-R
      11-26-2016, 04:52 PM   #11
Revnato
Revnato's Avatar
77
Drives: 12' X5M
Really excited for this group buy.
Would love to see more pics of the fitment, especially a front view with the down so we can see what the filters look like.
It'd also be cool to get up close videos of the induction noise. Is the sound difference very noticeable from stock?
Looking forward to updates!
Pure Stage 2 Turbos / JB4 / BPM tuned / Catless DPs / PTP Turbo Blanket / RK Intkakes / Eisnemann Sport / M Performance lip / IND Blackout / KWV3 Coilovers / MV Forged ML10 / Pirelli Pzeros / LED Headlights
      11-28-2016, 06:44 AM   #12
Cwash36
Drives: BMW X6M
I believe I read on another post that this application will work for the e71 x6m is that accurate?
      11-28-2016, 12:48 PM   #13
m5james
m5james's Avatar
Yes, the hood, grills, intake, etc are exactly the same.
      11-29-2016, 02:22 PM   #14
Sales@RKautowerks
357
Drives: e92 m3
Will have the first production set early next week, we've finalized the mold design and it's being machined this week, machining began yesterday.
Thanks
-R
      12-09-2016, 04:33 PM   #15
Sales@RKautowerks
357
Drives: e92 m3
Hey guys,
Received the first set of production intakes today, here are some pics! We will redyno and report back with numbers again as well as videos. Please contact us for purchasing your set!
Thanks
-R
pjoX5M2.50
      12-23-2016, 05:13 PM   #16
Sales@RKautowerks
357
Drives: e92 m3
Here are installed images.
-R
      03-09-2017, 11:44 AM   #17
gixxerboy63
Tanzanite Blue II X5M Pilot
gixxerboy63's Avatar
1040
Drives: M3, M4, X3 M40i, X5M
2017 m4  [0.00]
2010 BMW X5M  [10.00]
Did this happen?
2020 X5M - Tanzanite II
2012 M3 - Alpine White
      03-09-2017, 01:59 PM   #18
Sales@RKautowerks
357
Drives: e92 m3
Originally Posted by gixxerboy63 View Post
Did this happen?
Group buy never happened, product did come to life though.
-R
      03-15-2017, 12:41 AM   #19
m5james
m5james's Avatar
Prices come down yet to spark interest for a limited product on an already limited platform? What about the redyno you'd mentioned on 12/9/2016?
      03-18-2017, 11:58 PM   #20
Sicilian94
Drives: Monte Carlo bmw X5m
B
      03-20-2017, 05:30 PM   #21
Sales@RKautowerks
357
Drives: e92 m3
You're always welcome to call the number on the website for a set.
Originally Posted by Sicilian94 View Post
B
-R
      03-20-2017, 11:50 PM   #22
protecon
*May contain nuts
protecon's Avatar
Australia
193
-R
I guess the reason people aren't jumping on this, is you haven't really fixed a problem with the S63 - the factory intake location is exactly the same, and overall filter area between the two is similar.
Without demonstrating undeniable performance gains, irrespective of M-tax, you're asking people to drop US1300-1600 on essentially an aesthetic swap, which will only be seen when the hood is up and you're being Brian O'Conner.
Not sure what this cost to develop and manufacture, but you might get some bites at a lower price?
I'm sure I can speak for other X5M/X6M owners in expressing our appreciation to you for developing options for our platform, but with all the other performance mods stacked up before this, it would probably get pushed into the nice-to-have pile (IMO).
VMAX 0-1000M ▒ ▒ 230@22.619 > 232@22.489
m5james431.00
