      04-04-2015, 10:46 AM   #1
Wjjklj
Wjjklj's Avatar
Drives: 2020 BMW 740i
2021 BMW X7 40i  [6.50]
2020 BMW 740i   [5.00]
Upgraded Chargepipe for E70
My 2013 X5. 3.5i is leaking oil from where the chargepipe connects to the throttle body. I can of course visit the dealer and get this addressed but does anybody make a upgraded metal one for the E70's like is available on the N55 E90?
I also have what feels like a boost leak causing the car the shudder under heavy acceleration.
      04-04-2015, 12:29 PM   #2
kevinbahnz
kevinbahnz's Avatar
157
Drives: 2008 335xi sedan
that's probably where the boost leak is coming from. I had that with my e90 335xi , replaced it with an ER C-pipe and it went away. I would like to know if there's one for the e70 also.
<img src=http://i189.photobucket.com/albums/z164/kevinbahnz/08-23-2008030.jpg border=0 alt= />
      04-04-2015, 03:16 PM   #3
mitch808
Drives: 2012 X5 35i
I thought there is an F series intake that is compatible with the e70? Perhaps something there can replace it from the F series aftermarket?
      04-06-2015, 01:53 AM   #4
aj555
aj555's Avatar
Drives: 2012 BMW xDrive35i
I haven't messed with my N55 too much yet, so I don't know the similarities on it. But is there oil all in the charge pipe? I had a similar situation with my N54, where I had tons of white smoke coming out of my exhaust at a stop. Of course, everyone diagnosed it as blown turbos. Turns out the plastic oil/air separator that goes from the top of the engine to the charge pipe wasn't working and it was leaking oil all into my charge pipe which was getting shot into my engine. It became worse over time. I replaced it with an oil catch can, and the problem was solved. No more oil in the charge pipe, and no more white smoke out the exhaust.
2012 BMW X5 xDrive35i E70 Sport Activity
(Wife's Daily Driver) 2000 BMW 328ci E46 - less than 90k miles
(Gone) 2007 BMW 335i E90
      04-06-2015, 06:15 AM   #5
va335i
Drives: G07 X7 M50i
I had same problem on my N54. There is a O-ring that you want to check and make sure is there. My guess is they did some work on your car and forgot to put it back. Happened to me at the dealership, the boost leak made a mess of my engine right by the throttle body.
2007 335i sport sedan fully loaded, fmc, downpipes, PTF custom tune. Sold
2012 X5 50i fully loaded. ESS TUNE
2017 X5 M Donington Grey
