09-05-2012, 09:13 AM | #1 |
Rep 15
Conti DWS or Toyo St2
I'm getting ready for winter and am looking into getting a set of non-RFT tires for the 19" 212 rims I recently picked up.
Would love some info on which non-RFT would be best for northeast winter driving - Conti DWS or Toyo St2, or any other suggestions. I've heard the DWS can have vibration issues? I have a 2 yr. old, so I won't be doing any aggressive driving and would like a long lasting tire. Assuming anything will last longer and be more comfortable than the 20" Dueler RFT's I am riding on now. Thanks. |
10-22-2012, 01:30 PM | #2 | |
Rep 3,834
10-22-2012, 02:22 PM | #3 |
Rep 11,843
Drives: MY24 G01 AW Msport
conti dws
10-22-2012, 03:45 PM | #4 |
Rep 103
I've mentioned this in another thread but I went to the Conti DWS's on my last 4.8is and noticed no difference in tire wear. This is compared to Michelin Latitude's, Diamari's, etc. Regardless of what the treadwear indicates, they will wear out just as quickly in my experience.
The best thing to do is to get re-alignment and set the toe to as close as 0 in order to prolong tire wear. Watch out for excessive camber as well. Good luck!
Mitchell Phillipi, CCA#189329
'01540ias, '17x5M past:'96Dinan3, '11M3 ZCP, '11X5d, '15X5 5.0, '07AMdB9 |
10-28-2012, 09:51 AM | #6 | |
Rep 3,834
All alignment settings must be to factory spec for best factory handling, setting them to 0 will screw up all the testings BMW has done. After all, you didn't buy a BMW for its tire wear reputation, you bought one for the way it drives. With the toe setting being close to 0, it will become less responsive. Some reported the X5 pulling left/right after setting toe/camber to near 0. I got my DWS with an alignment by BMW to spec, it drives much straighter than before. Nearly no noise coming from the tires, compared to the Dunlop RFTs. I'm very sure it will outlast the 15k miles Duns. |
10-28-2012, 10:56 AM | #7 | |
Rep 118
I've read a LOT of reviews on here, bimmerfest, tire rack, etc and none of those have indicated any vibration from DWS tires. In fact, nearly 100% of DWS owners report that not only is there no vibration but there is also a lot LESS noise than other competitors so like others have stated, just look at any of the multiple DWS reviews on these sites for a clear picture. Now, having said that I am going to encourage you to buy the Toyo ST2s because (1) I have not heard of anyone else considering putting those on and (2) They look like a good option IF your not going to be doing a lot of driving in the snow (They have a low rating for snow but an exceptional rating for dry). Also, those of us with the DWSs will be providing reports of our experiences throughout our ownership but there isn't anybody (yet) to provide details of their experiences with the Toyo's so "go for it" and let us know how it goes... Someone else on here reported that they get the same mileage regards of the tire ratings but that can ONLY be as a result of their driving habits (consistent hard acceleration burning out rears or constant hard cornering resulting in wearing out the fronts) so that post has to be discounted. DWSs are a 540 treadwear rating whereas the Toyo's are 420 so (in theory) the DWSs should last a bit longer than the Toyo's but the ST2s also have 10% more tread depth (11cm instead of 10cm) so that may make up the difference and result in equivalent durability so your review will help those of us once our current set wears out. |
