      03-21-2020, 05:04 AM   #1
benjii
Drives: X6M
(Update)BMW X6M E71 - Engine warning light (metall on the top of the oil filter...)
Hi
When I drove to work the other day a "coolant low" message appeared. So to be safe i figured that the best thing to do was to fill the coolant reservoir at work. So i waited a couple of hours, then filled a bottle with water and filled up the reervoir to "min" level. The plan was ofcourse to change the coolant later with the correct stuff.
When i started the car couple of hours later to drive home, the Engine warning icon illuminated.
Is this maybe correaleted? or just a coincident? I drove my car carefully home and it has since been in my garage. It didnt have any ruff idle etc, drove as normal.
Thanks!
      03-25-2020, 09:31 PM   #2
1er_vert
Drives: 2007 BMW Z4 3.0si; 2010 BMW X6
Carly?
Scan it for codes...
2007 BMW Z4 3.0si - Hellrot
2010 BMW X6 M - Space Grey
      03-28-2020, 03:53 PM   #3
benjii
Drives: X6M
Thats the plan. But cant do it unitl wednesday, so just asking in the meantime.
      03-29-2020, 10:16 AM   #4
1er_vert
Check your battery voltage too. It needs to be minimum 11.6v cold and 14.6 max, while running.
      03-31-2020, 03:50 PM   #5
benjii
Drives: X6M
i'l check it out, thx.
      04-01-2020, 11:20 AM   #6
benjii
Drives: X6M
Update:I may be f****d! This piece of shit engine is ready to selfimplode:P
Today i had the car at an indy shop where a buddy of mine works. From the codes it only shows problem/code regarding intercooler or water pump, i think. This is a mercedes indy, so they dont have the proper diagnostic tools.
But the error message was 2F1E: LIN, comunication (charge air coolant pump 2) I think this has been there before.
Also, an engine fuel or oil venitlation line was broken off(A line that goes across the top of the engine) so it was replaced with something that fitted. My guy also changed the oil. And here comes the big "oh shit"
When he removed the oil filter he noticed there was alot of metal on top of the filter...(no metalic particles in the filter???) the metallic particles seems to be aluminum or something non magnetic.
Any guesses of what this can stem from?
(btw when he cleared the code, replaced oil, and fixed the broken line the engine lamp went out)
      04-01-2020, 11:34 PM   #7
yco
i'm just saying
yco's Avatar
5749
Drives: E71 X6M '10 (sold)
i dont know your cars history but no need to guess, you shouldnt drive the car like that unless you want to kill the engine..
      04-02-2020, 12:16 PM   #8
1er_vert
Get it scanned by Carly or ISTA.
      04-04-2020, 04:42 AM   #9
benjii
Drives: X6M
Hopefully it will last until i get to trade it in at a BMW-dealer. So their own messy(bomb) will blow up i their own faces.
Piece of junk!
Nice to drive though.
      09-03-2023, 06:20 AM   #10
kensou
Drives: bmw x6 m
Hi benjii
Did you solve the error message : LIN coolant pump charge air cooler missing ?
Thanks
