09-03-2012, 02:08 PM | #1 |
Rep 128
sport mode Vs. M mode
a quick questions to the more knowledgeble with the M X6, moving the gear shift activates the M/S mode which puts the car in the S for Sport mode (1) [or in the M for Manual mode if moving the shifter up or down].
Also, pressing the M button on the steering wheel unleashes the M dynamic mode (2). the question I have is; is the S mode (1) and the M dynamic mode (2) the same in the X6M or are they differtent, and if different, how so? |
09-05-2012, 10:58 PM | #2 |
2020 Mineral White 30d MSport
524
Rep 2,146
Drives: 2020 Mineral White 30d MSport
As far as I know, the S mode is no the same as the M mode, M mod is a custom mode you can previously program, like DSC, accelerator remapped and EDC, the S mode just makes the car feel more sportier mostly gearbox behavior.
09-13-2012, 09:29 PM | #3 | |
Rep 813
S mode is a transmission mode ( shifts faster, more aggressive upshift/downshift ) M mode is your specific MDM setting ( traction) Power (eco /power) EDC ( comfort , sport ) Also S mode behaves diff with M mode set to power and eco M mode is not the same as S mode as you can be in M mode with the gear in D ( Power on, MDM on but slower/less aggressive up/down shift) For around town im in S mode with M on MDM/ECO/Comfort with frequent stops the downshift is a bit too aggressive in auto (down to 1st/2nd gear coming up to a stop) for some hwy S mode , MDM, Power , Sport edc (unless construction)
Huracán Performante 18- Novitec Springs | RR SVR 19 | G05 X5 M50i | E70 11 X5M retired |
Jerez Black E92 10 m3 RE SSK | AFE Filter | Fabspeed XFC / Xpipe | AA ECU 1.5v | BMW PSW | Envy Charger | Megan Exhaust |
09-14-2012, 09:54 AM | #4 |
Rep 128
Good explanation.
So, if I understand you right; using the S mode alone gives a bit of a punch via transmission response while using M mode changes the dynamics of the car - using both is where the money is! Thx for the response |
09-15-2012, 04:43 PM | #5 | |
Rep 813
shifts are also much slower and smoother .
