      09-09-2021, 03:46 PM   #1
Flying Ace
Flying Ace's Avatar
4985
Drives: G05 45e, 997.1 & 991.1 GT3s
Oil Leak Passenger Side
My X5d just started leaking oil on the front passenger side, very close to the wheel.
I haven't had a chance to pulled the underside and figure out where it's coming from, but generally from that location where do you think the leak may be from? It's currently a very slow leak, about 1 oz over 8 hours
Maybe oil cooler lines?
      09-10-2021, 08:42 AM   #2
argento
argento's Avatar
538
Drives: 2013 X5M
You might get more hits in the General X5 Forum.
I had this same symptom, but found out it could be multiple issues. At first I was suggested it could be the vacuum pump or valve cover, but once they got in there it was my oil pan gasket, upper and lower. If the latter, I was given good advice to make sure the shop primes before running the engine. GL
