09-30-2020, 12:32 PM | #1 |
Rep 38
Drives: 2016 M5 Competition
Blower motor issue
Sometimes the AC blower will randomly increase the speed of the air flow when in auto mode and then settle back down to normal. This seems to be fairly random. Is this an indicator that the blower motor resister needs to be replaced?
09-30-2020, 04:05 PM | #2 |
Rep 38
Doing a little research it appears that on the e70 the blower motor includes the regulator (resistor) and it's fairly easy to get to. Is it worth just replacing the regulator?
10-05-2020, 07:23 PM | #3 |
Rep 133
Yes! it’s not hard to access my brother had a problem with his X5 AC not blowing at the setting he had it at (was always blowing on the lowest setting) if you take the blow motor out the resistor is attached right to it, did it in my driveway in like 30-45 minutes. I want to say there might be a relearning process for the resistor (i could be dead wrong) but when i put the new one in for him it would only blow on the highest setting for like a week or 2 then started to operate like normal
10-05-2020, 10:05 PM | #4 |
Rep 2,062
Mine does this randomly as well, just never really cared to address it. I haven't seen a fix for it though...got a link?
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's '97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's |
10-06-2020, 09:15 AM | #5 | |
Rep 133
https://youtu.be/qiNe9rbgPe0 the blower resistor is the silver piece attached to the motor itself and is really easy to change once the blower motor is out. |
