      09-25-2020, 01:26 AM   #1
chris604
Drives: X5 M
X5M Brake flush
Hi all. Just wondering if there's any special procedure to flushing the brakes on an M? Can I just use the bleeder tool and just pump it out with brake pedal? No need for abs bleed or anything like that?
And, just dot 4 fluid? Or something better like 600 F race brake fluid? What works best?
Thanks!
      09-25-2020, 07:41 AM   #2
Dollma
Drives: BMW x5d
I think you need a scan tool to bleed properly. Maybe do a search on here.
      09-25-2020, 10:56 AM   #3
Molez93
Molez93's Avatar
Drives: 2006 Z4M, 2001 740i
I’ve done my X5M a few times without using a scan tool in the process. A few folks get nervous about skipping the ABS actuator step, but I don’t worry about that. Never have- across various M cars, lots of manufacturers, and my track cars.
Fluid should be a low viscosity version like Pentosin LV, but there are others.
'01 740i Sport; ‘06 Z4M Original owner, no mods
'14 Lotus Evora S; '13 Subaru BRZ, track & autox car
Sold/totalled: E46, E39, 2 E53s, 5 E70s, E31
      09-25-2020, 10:57 AM   #4
Molez93
Molez93's Avatar
Having a pressure bleeder is awesome. One of the best ~$100 car maintenance investments I’ve ever made!
      09-29-2020, 10:09 AM   #5
Autobacs
Autobacs's Avatar
Drives: 2019 BMW X6M
Yes. Pressure Bleeder makes it a breeze. Tried the pump/bleed method and did not work for me. I just followed the Newtis brake fluid change procedure: right rear, left rear, front right, and left front, no abs procedure. That and BMW OEM DOT 4 Brake fluid and you are good to go.
2019 BMW X6M
2013 Lexus RX450H
2010 Nissan GTR AMS Omega 14
Molez9366.00
