      01-03-2018, 10:35 AM   #1
humbertob
humbertob's Avatar
Drives: '16 BMW M235i
Exclamation Noise at the tailgate area on X5? Check this first !
Are you experiencing weird noises at the tailgate area of your X5? Well there are 2 possible points that are the culprit. Check them in this order:
1. The hatch bolts on the lower tailgate assembly, mines were completely loose
2. The hatch stop rubbers on each side of the tailgate base, you can level those rubber stops using a T25 bit
My wife was tired of hearing the tailgate noise all the time and adjusting the bolts on the lower tailgate assembly and leveling the rubber stops on the tailgate base was the complete solution. Give them a try !
Happy 2018 to this awesome FORUM.
(OO)-(////)(\\\\)-(OO)
'16 F22 M235i
'19 G01 X3 | Wife's
'15 F30 335i M-Sport | Son's
'10 Porsche Boxster
boneca2000.50
      01-03-2018, 03:00 PM   #2
duckracer
Drives: 2011 x5 35i
Awesome! Mine creaks and I was about to start digging into it. Now I have a place to start. Thanks
      01-04-2018, 10:28 AM   #3
Naz24
Naz24's Avatar
Drives: W205 AMG C63 / E70 X5M
Mine just started rattling, i'll look into this.
I've heard of other forum members putting electrical tape on the lower U latches to reduce noise as well
2017 C63
2012 X5M
SOLD: 2015 M3; 2007 X3 M Sport; 2014 X3 M Sport 35i; 2004 X5 4.4i; 1994 325i
      01-04-2018, 12:27 PM   #4
socale39
Drives: 04 545i SMG
I’ve used felt tape instead of the electrical tape and it has helped tremendously. Don’t rule out the seat latches either as they can create a lot of noise as well.
      01-04-2018, 04:43 PM   #5
ryansbmw
Drives: 2013 X5 35i M-Sport, 2010 535x
Anyone get noise from the cargo cover? I've got a rattling going on over bumpy roads and can't figure out what it's from. I believe I am looking at the right latches and everything seems tight
      01-04-2018, 11:03 PM   #6
socale39
Drives: 04 545i SMG
It’s likely the latches for the 2nd row back rest. Add some felt tape to the U shaped loop on both sides and see if the noise subsides.
      01-05-2018, 09:53 AM   #7
JoeyBimX5din
Drives: 2011 BMX X5 Xdrive50i
if you hear creaks and rattles from your car, your exhaust isn't loud enough.
2011 BMX X5 Xdrive50i - 127K - No muffler, BMS Stage 1
2005 Jeep Grand Cherokee 5.7L V8-Her stock DD
1995 Ford Thunderbird 4.6 V8 LX - A bunch of mods BMW guys don't care about
1995 BMW 540i6 - H&R Lowering Springs, Bilstein's, Racing Dynamics Bars, Catback, Short shifter
      01-05-2018, 07:41 PM   #8
Colodano
Drives: 2010 X5M
Hahahaha
Every time I think that, I fire up my WRX and am reminded how much I like an actual exhaust!
I have some tailgate noises, but my tailgate also stays about 1/8 inch out at the bottom when fully closed, and the upper adjustments don't help. Is the latch in the lower half adjustable?
      01-07-2018, 09:37 AM   #9
humbertob
humbertob's Avatar
Hahahaha
Yes the latch at the bottom tailgate is adjustable and it tends to be loose some times !
'16 F22 M235i
'19 G01 X3 | Wife's
'10 Porsche Boxster
Colodano130.50
      01-08-2018, 10:13 AM   #10
JoeyBimX5din
Hahahaha
I won't be hearing any noises from my chassis, unless something is REALLY broken.
      02-26-2018, 03:09 AM   #11
gf_daemonio
Drives: 2008 X5
The bottom U-latch, wrap that up with felt tape or electrical tape. If that doesn't work, wrap your index finger around that U-latch and try to move it. If you feel any play, it's because the grease under that latch has leaked out. Disassemble to get to the that U-latch and add grease.
      02-26-2018, 02:34 PM   #12
heatmizr
Drives: E70 X5 50i M-Sport
WHICH Tailgate noises are you referring to for this solution?
The creaking/popping when going around turns? Or other?
heatmizr [Todd]
g26 i4 e40 - Clean Machine
e90 328i - sold
      02-26-2018, 07:45 PM   #13
RichardR0404
Drives: 2013 BMW X5 35D
Both of my shocks on lower tailgate are shot so they just drop down like a shitty Chevy truck. Looking into replacing them with something.
      10-13-2019, 10:37 PM   #14
nbhms
Drives: 2011 BMW X5 35d
What kind of grease should be used in the U-latch mechanism?
'11 E70 X5 35d
Tags
noise, rubber stops, tailgate
