11-05-2014, 10:08 PM | #1 |
STR8N-U
Rep 12
Catastrophic Engine Failure 2011 X5 50i
Hey all,
Had a major malfunction with my CPO 2011 50i M-Sport this morning. Was driving about 65-70 mph and went to accelerate when the car suddenly made a terrible grinding, shearing (metal falling on the ground) type of noise with very heavy vibration. After about 20-30 seconds of this, the engine malfunction warning came on but the engine never shut down. After I coasted off the highway, I looked under the car and it appeared that all of the motor oil had poured out of the engine with a long trail of it behind the car as well. I'm no auto mechanic but am assuming this was a broken piston rod? My question is this...Will the CPO warranty cover a new engine if that is what is deemed necessary? The car has 70K miles on it and is covered up to 100K I believe. Hoping to get a diagnosis from the dealer in the morning and trying to prepare against them screwing me too much. Any help/advice much appreciated! |
11-05-2014, 10:43 PM | #2 |
Rep 11,135
Mate, that sounds messy. This should absolutely be covered under warranty, unless they can prove your partly responsible for this engine to self-destruct.
11-05-2014, 10:55 PM | #3 | |
STR8N-U
Rep 12
What would a dealership say to try and blame engine failure on a driver? |
11-05-2014, 11:16 PM | #4 | |
Rep 11,135
11-06-2014, 12:28 AM | #5 |
Rep 40
Keep in mind that the dealership/service center wants to help you in this situation. It's corporate BMW that doesn't want to pay. Every time you service your car or have anything repaired under warranty the dealership makes money.
11-06-2014, 07:19 AM | #6 |
Rep 68
Sounds like your front drive shaft came apart. Haven't seen any n63 engines come apart on the highway. Should all be covered as long as you've done your maintenance. Have you had the driveshaft recall done?
11-06-2014, 07:24 AM | #7 | |
STR8N-U
Rep 12
I did have the recall on the drive shaft done last spring. I'll update this threD after I hear more from the dealership. |
11-06-2014, 09:41 AM | #9 |
STR8N-U
Rep 12
I thought that too, but I got the low engine oil level warning very quickly after the incident so I assume it was in fact engine oil. Still haven't gotten any info from the dealership.
I have a rental car currently. Any opinions on whether I shud expect to receive a loaner vehicle from the dealership for the duration of the repair? |
11-06-2014, 09:58 AM | #10 | |
Rep 11,135
11-06-2014, 10:08 AM | #11 |
Rep 600
Well known drive shaft failure ... damage to transfer case, transmission case, oil pan etc. - http://www.bimmerfest.com/forums/sho...d.php?t=714168
The recommended BMW inspection does not catch a possible imminent failure, especially when performed by a junior apprentice with a flashlight ...
PAX5
BMWCCA 20645 |
11-07-2014, 03:16 PM | #12 |
Rep 68
I've gotten to the point where I replace them all if it has the recall on it. Not sure if the new part is any different than the old one. Have a feeling it's the same shitty driveshaft.
11-08-2014, 02:16 AM | #13 |
Rep 2,232
Drives: Made in Bavaria
Wow hope it works out. Keep us posted.
'22 BMW M4 Comp (SSG/Black)
'16 BMW M4 (Shakir Orange/Black) - gone not forgotten '15 BMW M3 (Black/Black) - gone not forgotten '10 BMW X5M (Black/Black) - gone not forgotten '08 BMW M3 (Space Gray/Black) - gone not forgotten |
Tags |
cpo, engine failure, warranty |
