      01-23-2014, 07:30 PM   #1
jfiore13
jfiore13's Avatar
71
Drives: black 2018 M5
LED lights
So I brought my car (2011 X5 50i) into my dealer because after I put my LED interior kit in my car the SOS malfunction message came on. Along with that the tailgate lights went out. Also glove box wouldn't open. And lastly the radio wouldn't work. The dealership called me and they said it was the LED lights that caused everything to happen and said for me to switch back to stock bulbs. Could that be? The service rep said he warrantied 2,000 dollars in repairs and only charging me $300 for all the repair work so it doesn't raise a red flag to BMW corporate. Tomorrow I will go and pick up my car and test everything. Has anyone else experienced any similar problems? Just doesn't make sense to me why that caused those problems.
Thanks in advance,
John
      01-23-2014, 08:17 PM   #2
MnRiverman
Drives: 2011 X5 35d
2011 BMW X5d  [0.00]
I have had no problems after changing to all LED lighting in my 2011 35d.
      01-23-2014, 08:30 PM   #3
jfiore13
jfiore13's Avatar
71
Yeah I knew alot of people didn't that's why this doesn't make sense.
      01-23-2014, 08:41 PM   #4
larryv
larryv's Avatar
64
Drives: 17 M3 ZCP 11X5 M Sport 20 I3
No problems here. As for the Glove box not opening you blew a fuse. The fuse box is located under the dash on the passenger side front seat. You can do a search and find how to replace the 10 amp fuse. Did you use Canbus bulbs?
      01-23-2014, 08:56 PM   #5
jfiore13
jfiore13's Avatar
71
To be honest I'm not sure what type they are.
      01-23-2014, 11:10 PM   #6
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
Are these LED lights you installed from that group buy going on in the for sale sub-forum?
      01-24-2014, 11:13 AM   #7
Draper
Draper's Avatar
3461
Drives: M4 Comp / Macan Turbo
It's possible to blow a fuse when installing the glove box light (I did this myself...twice) which will prevent the glove box from opening. I suppose something similar could happen with the tailgate lights as well.
The SOS warning seems like a totally separate system though, and I imagine fused separately from any lights, whether they be interior or exterior.
However, their estimate of $2k might just be due to the fact the rear dome lights are such a PITA to swap out.
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic
      01-25-2014, 12:21 PM   #8
Capnhook
Capnhook's Avatar
Drives: 2012 X5 35d
Sounds to me the dealer just charged you $300 to replace a fuse and made it sound like they're the hero here only charging that much!
      01-26-2014, 11:07 PM   #9
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
Did you install the OEM BMW LED lights? Or some aftermarket eBay brand?
