10-29-2020, 07:54 PM | #1 |
Rep 75
Check engine light after replacing Upstream O2 Sensors
Hey all,
Recently, I was getting a Mixture Control 2 CEL on my 2013 X5 Xdrive50i. Figured it was the O2 sensors so I went ahead and had them changed out with Walker O2 sensors on the Upstream side. Both of them. Well, now I don't get the mixture control 2 CEL anymore but the following. Should I have gone the BOSCH OEM sensors instead? Is there something I'm missing here? Looks like I'm getting codes from both sensors malfunctioning now. Any help would be greatly appreciated. See below. |
10-30-2020, 10:12 AM | #4 |
Rep 760
Drives: 2019 BMW X6M
This is just a guess but my experience on the Lexus ISF platform is using Walker O2 sensors had the same issues and the advisory was stick with OEM Denso.
2019 BMW X6M
2013 Lexus RX450H 2010 Nissan GTR AMS Omega 14 |
10-31-2020, 04:08 PM | #5 |
Rep 75
So I switched to the OEM Bosch sensors and all is well. Only problem is that I am now getting the original Mixture Control 2 error. Any idea what else could cause this?
10-31-2020, 05:34 PM | #6 |
2022 M4 Comp Xdrive
1019
Rep 1,538
11-01-2020, 10:27 PM | #7 |
Rep 75
11-01-2020, 11:52 PM | #8 | |
2022 M4 Comp Xdrive
1019
Rep 1,538
What's the actual code you're getting now? And you may be able to reset adaptation by unplugging the battery for 2 mins or so. |
11-02-2020, 05:04 PM | #9 | |
Rep 75
This was the original reason I decided to change out my upstream sensors. Funny thing is when I installed the Walker sensors to start, I started getting the errors I noted previously and this one had gone away. Thoughts? |
11-02-2020, 05:50 PM | #10 | |
2022 M4 Comp Xdrive
1019
Rep 1,538
That shows up as System Too Rich (Bank 2) Try to swap bank 1 and bank 2 sensors, see if the code travels to bank 1 (with the sensor). |
11-02-2020, 07:34 PM | #11 |
Rep 75
11-05-2020, 11:46 AM | #12 |
Rep 75
11-06-2020, 01:16 PM | #15 | |
2022 M4 Comp Xdrive
1019
Rep 1,538
Worth a try for sure. |
11-09-2020, 03:02 PM | #17 |
Rep 75
The issue was presenting itself before I changed the upstream sensors and I'm getting the same code after 2 brand new sensors. I don't think switching sensors is going to make a difference at this point.
