      04-17-2014, 01:57 PM   #1
Lostx89xSoulz
Alpine White
Lostx89xSoulz's Avatar
Drives: 11 X5, 08 E93 M3, 09 E92 335i
need help with tire size
Hi forum member, I have a 2012 x6 3.5i xdrive and wanted to installed 22x10 rims all around. My question is that is it ok to installed square setup and what tires should I get so it doesn't mess up the xdrive? Any input is appreciated...
      04-17-2014, 02:55 PM   #2
upstate650
upstate650's Avatar
Drives: 2014 650xi Gran Coupe Msport
2020 BMW M340xi  [0.00]
you certainly can. Size isn't very imprortant if it will be square - its the wheels rotating at different speeds with mismatched tires that can screw up the xdrive. If you stray too far from stock diameter, your speedometer will be off, but that can be coded to the size of your tires.
2014 BMW 650xi Gran Coupe Msport Black Sapphire Metallic on full black merino leather. 20" M5 343M wheels for summer, 20" 373 wheels for winter with Nokian Hakkapeliitta 8 studded snow tires. M6 CP exhaust with M6 Diffuser and ///M Performance carbon fiber finisher. Mission Performance stage 1.5 and transmission tune.
      04-18-2014, 07:11 AM   #3
skforzagroup
skforzagroup's Avatar
Drives: Audi R8
i'd go with a staggered set up dont know why would wanna do a block set up for summers
2013 X5M Blue on White Leather
Mods: Miestershaft Remote GTC | ETG Tuned & AR DP |
2011 SLS Gullwing
Mods: H&R Springs | ETG TUNE | Miestershaft exhaust GTC| SKF Carbon Fiber Wheels
      04-22-2014, 12:31 PM   #4
Lostx89xSoulz
Alpine White
Thank you....
      04-22-2014, 12:34 PM   #5
Lostx89xSoulz
Alpine White
oh its just for now cause i like these rims. But however I'm getting the back lip extended soon. Probably another 2".
      04-22-2014, 09:48 PM   #6
titanle
titanle's Avatar
Drives: 2010 X6 Activehybrid
go staggered, looks way better! I got 295 up front and 335 in the rear with spacers and they still look sorta small in the wheel well.
      04-23-2014, 02:15 AM   #7
Lostx89xSoulz
Alpine White
Wow did you drop it? Planning to add lip and drop it with h&r 1.2 front and back.
