      04-28-2014, 08:47 PM   #1
BMW_Diesel_Owner
Drives: 2009 BMW X5 xDrive35d
Diesel Exhaust Fluid (DEF) - To drain or not to drain
Do we need to drain the Diesel Exhaust Fluid (DEF)? I was advised that we should drain it completely, and then replace it with brand new fluid. My vehicle has over 100K of mileage on it.
Is it necessary? As per the vehicle's design, DEF is used after combustion, so I don't see the point of why we need to replace the fluid. I understand why we need to have the DEF fluid, but throwing away what I currently have for the sake of having a new batch doesn't make sense to me.
Thoughts?
      04-28-2014, 10:58 PM   #2
Sylvan Lake V35
Vanilla Gorrilla
Sylvan Lake V35's Avatar
Drives: X5M & X5 35d
I have heard as it gets old it crystallizes and that is the reason you should drain it....I have never had an issue myself though and I do not drain it.
X5M, Eisenmann exhaust, 22" HRE wheels, catless down pipes, Stage II tune/X5 Diesel, Lowered & Tuned
      04-29-2014, 09:56 AM   #3
smyles
Drives: '21 X5
AFAIK BMW don't do it anymore. Obviously, for them cost cutting is the first priority, but nevertheless.
      04-29-2014, 07:44 PM   #4
Da M3nace
Da M3nace's Avatar
25
Drives: 04 M3
I had asked the same question on another post and the unanimous response was no, but who can you trust?
      04-29-2014, 11:59 PM   #5
grn.eyed.bandit
can you stand it?
grn.eyed.bandit's Avatar
Drives: 2010 Touring
there was an updated bmw bulletin i read somewhere that states they no longer drain the remaining fluid...simply top it up.
__________
When I get sad, I stop being sad and be awesome
__________
      05-01-2014, 06:55 AM   #6
BMW_Diesel_Owner
How do the 2 reservoirs work? Does the vehicle use the active reservoir first (the one located on the passenger side), and then give a warning message when it starts using the passive reservoir (the one located on the driver side, under the air intake)?
      05-01-2014, 08:00 AM   #7
finnbmw
Drives: 2010 & 2012 X5 xDrive 35d
The X5 uses DEF from the active tank and fills it up from the passive as needed to keep active tank filled. IIRC, the warning sign comes when the level in the active tank is low (and the passive tank is empty or the transfer pump is not working).
I plan to keep both tanks filled up (filling both of them up every 5,500 miles or so) and not wait for the tanks to empty. My thinking is that as the levels go down in the tanks, it leaves residual DEF on the tank walls, which then dries and crystallizes and over time falls down on the bottom plugging things up. Don't know if this will work, but I've seen this happen in industrial applications with other chemicals.
      05-01-2014, 02:10 PM   #8
Da M3nace
Da M3nace's Avatar
25
Drives: 04 M3
The passive tank is the one under the intake tube on drivers side? If so is there any issue in only filling up the active more accessible tank near passenger side? Do the two tanks not simply overfill into each other? I have only filled the tank on passenger side.
      05-01-2014, 06:35 PM   #9
ingenieur
ingenieur's Avatar
24
Drives: 2011 335d MSport
Under most circumstances the active tank is keep pretty much filled by transferring DEF from the passive tank. You will receive a warning once the passive tank is empty and the active tank reaches a certain level to remind you to fill them. If the SCR system is not operating properly to met emissions standards - that is another issue and causes an "Incorrect Exhaust Fluid" warning. This should not be ignored and should be addressed by your dealer straight away.
      06-30-2014, 02:42 PM   #10
Da M3nace
Da M3nace's Avatar
25
Drives: 04 M3
Does this sound like normal def fluid usage?
In the last 10k miles i have filled the truck with 4 gallons of def fluid. The first three times i used the 1/2 gallon bottles from dealer three different times after light to add def fluid came on. The most recent time the light came on i wated until the warning dropped to about 350 miles left b4 empty and used the entire 2.5 gallons jug i purchased online.
I would estimate that in the last 4k mikes i have used at least one gallon of def per 1k miles.
      07-10-2014, 04:04 PM   #11
note46
Drives: M Coupe, 328d SW, i4
that seems a bit high. and by bit i mean really high.
fyi get the def from vw dealer. at least around here (northern CA) it's a fraction of the cost of the bmw dealer. I got both the 1/2gal and 2.5gal for $25.
      01-07-2015, 07:27 PM   #12
Flying Ace
Flying Ace's Avatar
4985
Drives: G05 45e, 997.1 & 991.1 GT3s
what is the part number for the DEF fluid?
      07-17-2015, 09:31 PM   #13
Diesel X5
Diesel X5's Avatar
Drives: X5 35d X
I plan on doing the same. I just had my DEF tank replaced today under extended warranty as the check engine light came on. BMW says a low freq throttle valve and active tank faults.They found the heater had failed and was all gummed up.So I to am thinking the residual dries and crystallizes plugging things up.
      11-22-2015, 03:09 PM   #14
1mGator
1mGator
1mGator's Avatar
Drives: Valencia 1M
OK everyone, I have a 20111 X% diesel and my question is;
When you replace/refill the fluid does it automatically reset the seńsor or do you have to have a resort tool?
Thanks!
      11-23-2015, 06:30 PM   #15
smyles
Drives: '21 X5
There's nothing to reset
