      01-08-2015, 09:24 PM   #1
JupiterBMW
Self Proclaimed Roundel Junkie
JupiterBMW's Avatar
Drives: '11 E90 M3 & '13 F25 X3
Push it Real Good
I knew the thread title would get you in here...
So after storing my BBQ in the garage the other night, my wife and I realized it had been leaking propane from the tank into the garage (horrible smell when we went out to pack the kids into the X5). My first thought was do NOT start the X...
So, we realize we needed to push it out of the garage and down the driveway before starting it. I had never pushed it but was somewhat familiar with the process. Figured I would type it up here for anyone that has never done it, it was pretty easy.
1. Turn the vehicle on, ignition on (press start twice, no foot on the brake).
2. Grab the little red t-handle in the trunk under the floor.
3. Lift up the rubber from the cupholders in front
4. Use the t-handle to unscrew the cap in the driver's side cupholder.
5. Put your foot on the brake and release the parking brake.
6. Insert t-handle into the socket under the cupholder cap, twist counterclockwise and hold (it is spring loaded and will return if you let go).
You will notice that while holding it, the dash will show the vehicle in Neutral. Have someone push...
I didn't realize it'd be so easy. No warnings, no error messages, it actually just worked. I was surprised.
Oh, and since I'm posting this from the kitchen, clearly we didn't blow up the house, the X, or the kids! Win!
2018 F15 X5d Carbon Black/Nutmeg Individual- Oil Burner Tow Rig
2013 E82 1M3 Carbon Black/Black- S65/DCT Track Toy
2013 F25 X3 35i Alpine White/Chestnut- German American Family Hauler
Past: '11 E91 335is, '11 E90 M3, '10 X5M, '14 328d, '03 330i Dinan3 ZHP, '04 330i ZHP, '12 X3 35i
      01-09-2015, 03:09 PM   #2
P1
P1's Avatar
11569
Drives: 2004 3/4 ton Duramax
That's good to know mate. Best to take a screen shot of this in case I ever need it.
      01-09-2015, 04:05 PM   #3
jiggz
Drives: E90 M3|F15 X5 50i
Wow, I would have never know this Jon. Good to know, though hopefully I never need to do this!
      01-10-2015, 04:12 AM   #4
JupiterBMW
JupiterBMW's Avatar
Glad you guys approve. I had always wondered how I could/would push/roll the newer BMW models, glad I know now. And glad its super easy!
      01-10-2015, 11:28 AM   #5
boogakb24
Drives: 325i
That was catchy tile!!!!!
Good to know
      01-10-2015, 12:37 PM   #6
theonesupreme
theonesupreme's Avatar
11
Drives: X5M
It works even the car didn't start with ignition on, because it is designed for the car to be towed away from any damage on the x-drive system onto the flatbed.
Most of the tow driver should know about this.
X5///M WHITE, VELOS STAGE 2, AKRAPOVIC DOWNPIPE + FULL EXHAUST, KW V3 , VORSTEINER FRONT LIP + REAR DIFFUSER.......ETC
      02-13-2016, 10:27 AM   #7
RideM5
Drives: 2013 X5M
FYI in my 2013 you cannot use this tool to manually release the transmission. Not sure when/ why bmw changed this, but it makes things much more difficult when you need your car towed from your garage.
      02-14-2016, 12:13 PM   #8
black1
black1's Avatar
Drives: Pure Metal M6GC
Thanks for sharing, never even thought about it or wouldn't even know where to begin
      02-14-2016, 12:55 PM   #9
omgboost
Drives: 2012 X5 35i
Yes, in my 2012, I don't have the tool. But if you remove the rubber from the cupholder, you'll see the square there where the tool should be inserted in.
      02-14-2016, 02:29 PM   #10
RideM5
Drives: 2013 X5M
My cup holder has the removable cap as well. Unfortunately, if you remove the cap, there's nothing under it. It was pretty frustrating finding this out when I really needed it.
      02-14-2016, 02:40 PM   #11
JupiterBMW
JupiterBMW's Avatar
Hmm, that sucks for you guys... Not sure what to do on a 2013 then...
      02-14-2016, 03:08 PM   #12
temporaptor
temporaptor's Avatar
64
Drives: 11 335D MSport / 12 X5 35d
The release under the cup holder went away with the 8 speed transmission. The 35d had the 6speed till the new body style came out so they all have the release under the cup holder. For the 8 speed transmission you have to crawl under the car to put it in neutral.
      02-14-2016, 03:43 PM   #13
RideM5
Drives: 2013 X5M
That may be true, but my 2013 x5m has the 6 speed transmission and does not have the cupholder release. The dealer tech says they do have a release under the car, but it was easier to get it out using skates to help slide it out.
      02-14-2016, 08:09 PM   #14
JupiterBMW
JupiterBMW's Avatar
Ahh, skates, thats a good idea for sure... As for the new vehicles with the 8 speed, that sounds ridiculous!!
