07-17-2019, 06:15 AM | #1 |
Rep 3
BMW X5 E70 Error Code P0019
Would you please help to solve this issue in my car
my BMW X5 2009 has Low Oil Pressure warning in the dashboard, the RPM is not stable and fluctuating, also the motor performance is significantly degraded. I flushed the OIL however this issue not solved. I did online research and some threads mentioned something about changing the crankshaft sensor, I'm not sure if this will fix the issue? I did an OBD scan I got the below error code: VIN retrieved from Vehicle VIN: WBAFE81099L095076 Make:BMW Year:2009 ----Confirmed Trouble Codes Scan Report---- 4 Confirmed Trouble Codes Trouble Codes: 1. P0019 Crankshaft Position - Camshaft Position Correlation Bank 2 Sensor B 2. P0302 Cylinder 2 Misfire Detected 3. P0300 Random/Multiple Cylinder Misfire Detected 4. P0303 Cylinder 3 Misfire Detected |
07-17-2019, 06:55 AM | #2 |
Rep 549
Im not sure if the oil pressure light is related to the codes, but since your codes tell you the camshaft sensor is faulty I would get that fixed 1st. A failing sensor will absolutely mess with performance of the engine.
07-18-2019, 04:27 PM | #3 | |
Rep 3
I did find some factory manual troubleshooting suggestions: P0019 Exhaust camshaft 2, tooth offset to crankshaft Possible causes: - Cam sensor - Solenoid valve - Timing - VANOS servo unit - Timing chain |
08-12-2019, 10:08 AM | #4 |
Rep 3
Please help me to understand...
Sensors seem to have a much higher failure rate then the physical parameter that the sensor are supposed to monitor... So why not simply remove sensors? Every time a got a check engine light, they replace a sensor but not the thing that could cause the real issue. |
04-17-2024, 07:19 PM | #5 |
Rep 14
just giving a lead to anyone who may come across this old post. I had crankshaft camshaft codes vanos codes, random misfires 4,5,6,8 exhaust turbo charger coolant pump. dsc codes. in short everything going wrong. Disconnected the ibs and reset adaptations. everything is gone. IBS was faulty
