      02-12-2017, 04:14 PM   #1
tcohrs93
Drives: 2012 X6
2012 X6 N63 metal in oil...
Have a 2012 X6 with some engine issues... I called my local BMW dealer and had them look up the service history on this vehicle. They told me the CCP was done back in May of 2015, exactly 14,000 miles ago from what it currently has... I pulled the oil filler neck out of the valve cover so I could watch the timing chain as I cranked it over. Didn't see any issues there. Then I decided to take a look at the oil filter and immediately found a major issue. The oil was very shiny, metallic colored and I could see lots of little metal pieces in the filter itself. I realize this is about the worse case scenario I could have here. Any idea what could cause that to happen on this engine? Is there any chance BMW will do anything to help me out with this issue? Thanks!!
      02-15-2017, 08:03 PM   #2
Ryan5034
Drives: 2019 X5 50i
Have you considered an oil analysis to confirm your diagnosis?
      02-19-2017, 04:38 PM   #3
-c-
-c-'s Avatar
Drives: bmw
Well not that you would but I'd trade it in asap and walk away!
Metal in oil is never good and with your compression tests being what they where it's possible it's a ticking time bomb !
Cut your losses and run!
      05-21-2017, 02:26 PM   #4
GAM
GAM's Avatar
39
Drives: 2014 M6 Gran Coupe
Tchhrs93, can you give us more info on what happened next?
