      12-31-2023, 11:29 PM   #1
RaysF30N55
Drives: 2012 F30 335i
2012   [0.00]
2008 4.8i ekpm3 location help?
I have a 08 4.8i with 3rd row seat and for the life of me I can't find the EKP module.
does anybody know where the ekp module is located?
I already pulled both back seats out ( not the 3rd row seats) nothing under the seats
I semi pulled both back rear covers left and right and nothing behind there
I pulled the plastic trims both sides where the seat belt mounts and there's nothing.
I pulled the rear cover to battery and pulled the 2 rear covers where the fuse box and the amplifier is at and nothing! the only thing I see is the green fuel relay
THIS IS CRAZY THAT ITS NOT WHERE IS SUPPOSED TO BE AT.....
Or just my year of x5 it doesn't have the ekp...
      01-03-2024, 08:36 PM   #2
jbash87
2012 BMW X5 35d  [10.00]
2006 BMW M5  [10.00]
Not sure you have one based on my limited searching. What makes you think you do? Do you have a part number you're looking for?
      01-06-2024, 06:01 PM   #3
RaysF30N55
2012   [0.00]
I came up with the same conclusion, I couldn't find anything on my year and model even it didn't show up on realoem
because every other bmw I have owned and on my f30 335i has one.
I had a problem with my x5 randomly turning off on me while driving, I swear it could've been EKP since I know they are know to be faulty with time.
but on mine model all I have is the green relay so I swapped that out and still had the same problem. but I found out it was the pump being faulty I had swapped out the pump and haven't had the problem since.
      01-06-2024, 06:22 PM   #4
jbash87
2006 BMW M5  [10.00]
Is this your first port injected Bimmer? Just a theory, but I'm thinking that EKP modules are only found in direct injected motors.
