      02-22-2019, 09:52 AM   #1
titanle
titanle's Avatar
Drives: 2010 X6 Activehybrid
Would these wheels fit? Urgent!
I got the same rims in +25 offset but the front calipers rubber on the inside of the rim. Not the back of the spokes but the inner diameter. Would +40 offset make them fit?
Thanks
      02-22-2019, 12:21 PM   #2
titanle
titanle's Avatar
Anyone?
      02-22-2019, 12:52 PM   #3
Bilbofraggins
Bilbofraggins's Avatar
Drives: 2013 X6M, 2019 X3 M40I
40’s will work...for a parallel set up...
      02-22-2019, 03:20 PM   #4
titanle
titanle's Avatar
Yes I’m planning on doing 20x10 on all corners. The tire shop suggested 275 front and 315 rear on theee rims. Does that sound okay?
      02-22-2019, 04:49 PM   #5
Bilbofraggins
If you’re asking if a 315 will fit on a 10 inch rim vice an 11inch...I think most would say not usually, but may be possible... There are websites that can tell you the tire width range on a particular rim width
      02-22-2019, 04:51 PM   #6
titanle
titanle's Avatar
Thanks for the reply. I think I may just go with 20x10 and 275 40 20 on al corners
      02-22-2019, 05:08 PM   #7
Bilbofraggins
Tire widths for a wheel/rim size chart - Equivalency table
Rim width (inch) Min. tire width (mm) Max. tire width (mm)
8,5 225 255
9,0 235 265
9,5 245 275
10,0 255 285
12 more rows
Tire Width for a Wheel/Rim Size Chart - Tyre Plus Sizing Calculator
      02-22-2019, 06:17 PM   #8
titanle
titanle's Avatar
Thanks!
