02-16-2019, 01:19 PM | #1 |
Rep 115
22 inch tires size
Hey guys, i got some TSW mirabeau 22x10 for front and 22x11 for the back of my 2013 x6 50i. My buddy told me to get some 265/35/22 for front and 305/30/22 for the back but i can't get a definitive answer off the net or tire shop guys. What are you guys running on similar setups?
02-16-2019, 04:14 PM | #2 |
i'm just saying
5738
Rep 2,634
well i wont give you definite answer but i will tell some facts..
front 265/35/22 and rear 305/30/22 combo your rear tires will be smaller.. i donno if you re trying to cut tire cost or something but 22" and 10" base 265mm width.. are you serious? 10" should be wider from your OEM rims already.. you should have 9 or 9,5" rim base as stock.. if i were you.. i wont go with 22" but you ll need lowering kit also.. cause car ll be higher after installation than before you ll notice.. im not sure if you have adaptive rear suspension.. if you dont it ll be a cheaper and easier installation.. i d go for that with.. 275/35/22 and rear 315/30/22.. but you have wilder options.. front 285/30/22 and rear 335/25/22 (will be too expensive) front 295/35/22 and rear 325/35/22 (will be less too expensive) |
02-22-2019, 08:45 AM | #6 |
Rep 3,035
Drives: 2022 BMW X5
295/30ZR22XL, 335/25ZR22XL are the correct sizes for 22" wheels!
02-22-2019, 11:04 AM | #7 |
Rep 115
i wound up ordering that combo after the shop put on the 305 and 265 and the lip of the rims are sticking wayyyy out. It doesn't look right, i wonder what the return policy is for tires with 10 miles on them.
02-22-2019, 05:22 PM | #8 | |
Rep 3,035
Drives: 2022 BMW X5
depending on the place where u bought them from I would try to sale them locally...
