      06-14-2018, 01:39 PM   #1
Yanchii
Moldova
59
Drives: 09 BMW X5 35D
Finally deleted DPF/SCR & EGR!
Well guys I have done it! Stage 2 tune by Malone tuning. I'm so happy with this setup! The power increase is amazing! And I'm in love with the turbo noise, I also have jbd on at 50% so going to get it on a dyno soon and see what the real numbers are!
      06-14-2018, 01:42 PM   #2
sunny_j
sunny_j's Avatar
211
Drives: 2012 X5d
you are stacking the Malone tune with the JDB?
2012 X5d | Deleted & BRR Tuned | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Thread
https://www.xbimmers.com/forums/show....php?t=1529213
      06-14-2018, 07:47 PM   #3
socale39
Drives: 04 545i SMG
^^^ this?
      06-15-2018, 03:46 AM   #4
Yanchii
Moldova
59
Yes! JBD running at 50%
      06-15-2018, 03:08 PM   #5
sunny_j
sunny_j's Avatar
211
Drives: 2012 X5d
Why though? Makes no sense. I've driven my buddies x5d with the Malone stage 2 tune and it doesn't need more power. Even on my x5d, I'm running the JR stage 2.8 tune and there's plenty of power.
Don't think it's a good idea to stack a jdb box on top of a tune
      06-15-2018, 05:52 PM   #6
Yanchii
Moldova
59
Why though? Makes no sense. I've driven my buddies x5d with the Malone stage 2 tube and it doesn't need more power. Even on my x5d, I'm running the JR stage 2.8 tune and there's plenty of power.
I just didn't want to remove it and I saw on a forum that someone else stacked it and they were fine.Didn't think it would hurt anything. Unless you can inform so I don't break anything because of it.
      06-15-2018, 07:16 PM   #7
socale39
Drives: 04 545i SMG
I’d be concerned about the fuel pressure. This is how the JBD gets more power and most people will only max out at 80% on a stock tune. I’d be curious to know if the other tune has increased the fuel pressure and by how much as that could be compounded with the JBD. The issue is when you have too much pressure there is a valve to control it, if you are constantly making that valve work and it eventually fails, then what?
      06-15-2018, 08:57 PM   #8
sunny_j
sunny_j's Avatar
211
Drives: 2012 X5d
I ran the jbd @ 100% since the day I bought the x5 brand new back in 2012. I would occasionally get the reduced power malfunction.
      06-16-2018, 08:45 AM   #9
Yanchii
Moldova
59
I ran JBD at 100% as well, and only got a reduced power several times but that's about it, I see what you mean. I didn't think about that, I figured pressure was only increased as throttle was increased?
      06-16-2018, 01:39 PM   #10
335dsleeper
Drives: 09' 335d 10'35D
Malone tune has conservative rail pressure. Stacking the JBD will add power but can also damage injectors. 1900bar is about max the Injectors will handle. The rail sensor maxes at 1840bar. The JBD tricks the sensor thus tricking the dde. Too much pressure will damage the Injectors.
Truth be told, power is limited my the torque limiters, so, if you’re adding fuel via a JBD, you’re till limited by the torque limiter. Lastly, the edc17cp09 dde uses Lambda for tuning. If you stack the JBD and you add fuel, the DDE will adapt eventually pulling fuel other ways to hit target lambda.
If you want more rail pressure in your tune, PM me.
Yanchii58.50
      06-16-2018, 02:35 PM   #11
335dsleeper
How do they compare?
Which is faster?
      06-16-2018, 03:48 PM   #12
Yanchii
Moldova
59
Ah okay, I had no idea! In other words JBD has to go?
      06-16-2018, 04:39 PM   #13
335dsleeper
Not that it has to go, you have safety with Malone’s rail pressure but, the dde will start to adjust for the additional fuel.
      06-17-2018, 11:37 PM   #14
GizmoPhoto
Drives: 2011 BMW x35d
INBOXED
      06-18-2018, 01:31 AM   #15
sunny_j
sunny_j's Avatar
211
Drives: 2012 X5d
Which is faster?
Power wise they are about the same. Malones tune creates more soot and diesel fumes compared to the JR tunes.
He's on vacation right now but I plan on drag racing him (on a closed course) when he gets back. His x5d has the same options including 20's wheels. Should be interesting...
I still gotta sell my JDB box. It's sitting collecting dust now.
Build Thread
      06-18-2018, 06:11 AM   #16
Yanchii
Moldova
59
Which is faster?
Yes Malones tune gives you lots of soot lol then again I have JBD hooked up so that probably plays a role in that.
