      12-02-2015, 04:31 PM   #1
XFIVEM
Drives: X5M
F85 Rotors on E70 X5M
Good day Gents. Just finished this great upgrade and decided to share with you guys.
Will post better pics later.
      12-02-2015, 05:52 PM   #2
blue dragon
Drives: '22 Tesla MY + '23 Tesla MY
Interesting, I will need new front rotors soon
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
      12-02-2015, 07:19 PM   #3
Crazy1323
Drives: X5M
Great to hear, were they just a bolt on? Did anything else have to be changed?
      12-02-2015, 07:42 PM   #4
TheVazha
Drives: X5Mmmkay.
Post part number and source you newb.
Lol jk, but please post! Looks amazing and a no brainier for next replacement!
      12-02-2015, 08:10 PM   #5
XFIVEM
Drives: X5M
F85 requires two bolts on the front and rears rotors to hold them in place.
E70 requires one bolt on the front and rear rotors to hold it in place.
I was able to use only one bolt on the front and non on the rear due to the bolt hole not being in the same spot as my oem rotor so i used the wheel bolts to hold it in place.
      12-03-2015, 03:37 PM   #6
Gatoferoz25
BeastM3r
Gatoferoz25's Avatar
Drives: M3 COMP
Good info Brother
MORR WHEELS - VORSTEINER HOOD - FRONT LIP-CF REAR DIFFUSER - LED HEADLIGHTS - BREMBO BRAKES - Kw SUSPENSION - EISENMMAN - JB4 - SPORT STEERING WHEEL..!
      12-04-2015, 02:13 PM   #7
jrmccain
jrmccain's Avatar
Drives: 2022 M5C
Looks great! I will be doing this when it's time for replacement. I don't the 1vs2 rotor bolts will make any difference. After all, the lug nuts are holding pretty hard.
      12-04-2015, 06:25 PM   #8
mitch808
Drives: 2012 X5 35i
Pretty much this. One could argue, you don't need any at all since again, the lugnuts are applying their force to the hub
      12-04-2015, 11:03 PM   #9
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
The difference being they're just drilled rotors, correct?
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      12-05-2015, 12:44 AM   #10
theaudir8fan
theaudir8fan's Avatar
Drives: a major headache
m5james nope, the main difference is that the new once are a 2 piece design
      12-05-2015, 12:48 AM   #11
m5james
m5james's Avatar
Oooohhhh ahhhhh. Other than cost, is there any proof of better stopping power then.
      12-05-2015, 05:20 AM   #12
X Driver
X Driver's Avatar
Switzerland
70
Drives: X5M Black Fire Edition
They are at the e70 compound allredy.
      12-05-2015, 07:47 AM   #13
Gatoferoz25
BeastM3r
Drives: M3 COMP
I don't want to Jack ur tread brother just throwing this out for someone that doesn't want to pay retail costs.
I have a set for sell front and rears for a local lucky guy M .
Contact me 2016586969 if u r in a need of replacement rotors or want to upgrade to F85-F86 new Rotors thanks
      12-05-2015, 12:21 PM   #14
mitch808
Drives: 2012 X5 35i
Rotors dont stop a car. Period.
      12-06-2015, 12:21 AM   #15
theaudir8fan
No one can prove anything at this stage since the combination isn't tested, but theoretically, the 2 piece design should offer better fade resistance due to better cooling and lighter weight will result in less inertia. I doubt there will be a difference driving normally, but there probably are some improvements in a heavy use scenario such as track
not sure what you mean
      12-06-2015, 08:42 AM   #16
X Driver
X Driver's Avatar
Switzerland
70
I mean they are two peace allredy, center is alloy. We call them compound disks..
      12-06-2015, 04:31 PM   #17
theaudir8fan
I see what u r saying, but even tho original E70 M rotors is technically a 2 piece, they do still have a large portion of the iron disk that is molded into the center hub. What I'm referring to is by 2 piece is the usual design where the iron rotor ring is just the ring it self and the majority of the hub is alloy which attaches to the rotor ring itself by hardware, this is more inline with aftermarket big brake kit rotor designs
      12-07-2015, 08:46 AM   #18
X Driver
X Driver's Avatar
Switzerland
70
You are right...
      12-08-2015, 02:15 AM   #19
JupiterBMW
Self Proclaimed Roundel Junkie
JupiterBMW's Avatar
Drives: '11 E90 M3 & '13 F25 X3
Bravo, this is awesome! Damn though, they aren't cheap!
2018 F15 X5d Carbon Black/Nutmeg Individual- Oil Burner Tow Rig
2013 E82 1M3 Carbon Black/Black- S65/DCT Track Toy
2013 F25 X3 35i Alpine White/Chestnut- German American Family Hauler
Past: '11 E91 335is, '11 E90 M3, '10 X5M, '14 328d, '03 330i Dinan3 ZHP, '04 330i ZHP, '12 X3 35i
      12-08-2015, 04:54 AM   #20
mitch808
Drives: 2012 X5 35i
2lbs removed at the wheel, is more beneficial than 2lbs removed at the rotor when it comes to acceleration. Like going from RFT to non-RFT's.... 2lbs off the hub/rotor gives better suspension response, which is also a good thing, but not as noticeable.
      01-11-2016, 01:34 PM   #21
Cattivo
FDNY Engine 55
Cattivo's Avatar
My rotors need replacement, the F85 rotors will be my new replacements
      01-11-2016, 08:25 PM   #22
theaudir8fan
Going from RFT to non-RFT is beneficial, however conceptually, reducing mass from the rotor and the wheel itself in this case is no different as both of these are rotating mass, what you are referring to is if the reduction came from moving components such as the hub carrier but not rotating mass which the brake rotor is a part of
