      02-03-2014, 01:45 PM   #1
upstate650
upstate650's Avatar
Drives: 2014 650xi Gran Coupe Msport
2020 BMW M340xi  [0.00]
KW V3 coilover settings
A set of KW's will be appearing on my doorstep on Friday. Anybody want to share their settings? I have searched the forums for this info, but it seems that everyone just runs the stock settings. Anyone willing to share their thoughts on ride quality at the stock settings, or any custom setting they have arrived at?
Thanks in advance!
      02-03-2014, 05:28 PM   #2
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
Not to threadjack but I would like to add to your question-- is there an order to follow when making the adjustments? I've heard both ways on this.
I'm at the stock settings currently as well.
      02-04-2014, 12:00 PM   #3
Roychimac
Roychimac's Avatar
Drives: 15 YMB F80
I run 55 front and 50 rear. So far it's been good. Better than stock ride and confident through the turns and most importantly - NO BOUNCE!
      02-04-2014, 12:03 PM   #4
upstate650
upstate650's Avatar
How low are you - all the way down? Pics?
      02-04-2014, 12:22 PM   #5
Roychimac
Roychimac's Avatar
Drives: 15 YMB F80
not all the way down - can go much lower.
Name:  image (2)medium.jpg
      02-04-2014, 12:29 PM   #6
upstate650
upstate650's Avatar
looks f'in bad ass! How do you you adjust the ride height on these? Can you do it with them installed or do you have to take the wheels off to get to it?
When you say 55 front and 50 rear, what are you referring to? I thought you just counted the clicks when setting them up?
what size wheels are those, and which wheels? Love the 5 spokes!
      02-04-2014, 12:33 PM   #7
Roychimac
Roychimac's Avatar
Drives: 15 YMB F80
Thanks man. You count 55 and then 50 from open position I think. You will need the rims off and the car jacked up/hoisted.
These are my winter wheels - XO rims in 22s. Ya I'm loving the design too. Just hate how they don't come staggered or in a wide setup. I run a 10.5 square setup.
      02-04-2014, 12:48 PM   #8
upstate650
upstate650's Avatar
I feel you. I am running a square 20x10" set up. Love those XO wheels! was looking at those myself for summer, but not wide enough!
      02-04-2014, 03:23 PM   #9
UnicornM
UnicornM's Avatar
Drives: M
For those with air bags on the rear. I hear alot of folks with the H&R springs complain about bounce on the rear when set to low. Is this the same when running the KW V3s? I'm planing to get it pretty low but I'm little concerned that's just a trate with the rear leveling setup.
      02-04-2014, 03:29 PM   #10
upstate650
upstate650's Avatar
H & R only bounces if you adjust it too low. The beauty of the KW is you can slam it and still no bounce.
      02-05-2014, 06:08 AM   #11
UnicornM
UnicornM's Avatar
Drives: M
Is this largely due to the H&R setup using stock rear dampers?
      02-05-2014, 07:57 AM   #12
upstate650
upstate650's Avatar
I think it's mostly because of the lowering link/ air suspension combo. Non airbag rears use a spring and have no problems.
      02-05-2014, 10:47 AM   #13
UnicornM
UnicornM's Avatar
Drives: M
Which for me is a problem if I want to slam my 5. I have airbag rears so will still need the lowering link, hence my concerns over bouncy ride.
      02-05-2014, 11:18 AM   #14
upstate650
upstate650's Avatar
Can't slam it with h and r kit. Ride will be intolerable. The picture I posted is about as low as you can go.
      02-05-2014, 12:13 PM   #15
UnicornM
UnicornM's Avatar
Drives: M
Indeed, but how tolerable is it with airbag rear and KWs.. slammed? I'm thinking the excessive 'bounce' is largely to do with the OEM damper bottoming with H&R setup Vs fully matched damper setup of that with the KWs
      02-05-2014, 12:25 PM   #16
upstate650
upstate650's Avatar
By all reports, stock ride even slammed. I will let you know what I think in a week.
      02-05-2014, 01:12 PM   #17
Roychimac
Roychimac's Avatar
Drives: 15 YMB F80
Mine rides fantastic!
      02-05-2014, 03:53 PM   #18
UnicornM
UnicornM's Avatar
Drives: M
Does you '6' have air bags on the rear then? I'm just trying to see if KWs slammed is not a problem mainly on airbag vehicles vs springs. One thing is common, H&R and KW use little links.. but I'm guessing the KW damper is what alleviates the rear from bouncing vs H&R with stock dampers.
      02-05-2014, 10:02 PM   #19
theonesupreme
theonesupreme's Avatar
11
Drives: X5M
I have a post there but, no one shared about the hard and soft detail for the front and rear...
any shop in NYC will provide the best install service for KW V3?
      02-05-2014, 10:57 PM   #20
theaudir8fan
theaudir8fan's Avatar
Drives: a major headache
No, the KW swaps out the entire rear set up for it's own damper and coiled springs, so no more airbags
      02-06-2014, 05:58 AM   #21
UnicornM
UnicornM's Avatar
Drives: M
Sorry to theonesupreme for hijacking your thread buddy
Are you sure? All install pics i've seen with rear air bag still in place with change over of damper only!
Edit: added pics. Also check out the 3D Design coilovers from Japan for the X5/X6
      02-06-2014, 10:07 AM   #22
theonesupreme
11
Drives: X5M
I have the same set installed, X5/X6 with the edc should have the set shown in the pic?
