      10-23-2014, 03:35 PM   #1
fyim
fyim's Avatar
Drives: E92
BMW X6 MY09 steering wheel retrofit?
Is it possible to retrofit X6M steering wheel to a normal X6? I would like to have the paddles: left "-" / right "+". I've seen 2013/2014 X6 steering wheels with paddles like this
Thank you very much
      10-23-2014, 10:05 PM   #2
n_sievers
Drives: 2012 X6M Monte Carlo Blue
2012 X6M  [0.00]
You can just purchase the +/- paddles and are a direct swap or can do as I did by swapping the pins in the electrical connector (located behind the airbag) to existing paddle on the right side thus causing upshift upon pulling.
      10-24-2014, 02:33 AM   #3
fyim
fyim's Avatar
Drives: E92
So if i will buy a X6M steering wheel it will be a direct swap, no coding needed?
Thank you very much
      10-24-2014, 08:02 PM   #4
n_sievers
2012 X6M  [0.00]
To the best of my knowledge it should not require coding. If you are going from non heated to heated there may be coding activation required to activate that function but do not know that for sure. Just note that 09 has the CCC idrive and that wheel has the programmable "star" and "diamond" buttons whereas a 10+ with CIC idrive has printed radio mode and recirc buttons. If you would want to maintain the button integrity then could most likely just swap the switch button grouping.
      11-22-2014, 01:31 AM   #5
sycd
sycd's Avatar
Drives: G87 M2 [MT]
2023 BMW M2 [MT]  [0.00]
2020 BMW X3M  [0.00]
Interesting. What if the stock car doesn't have paddles at all? Would a steering wheel like the X5M wheel with paddles work also in that case? Is it all already prewired?
Mine has the line departure detection, no heat, no paddles. Otherwise the car is a 50i loaded with M perf pkg.
I wouldn't mind upgrading to a X5M wheel or M perf alcantra wheel.
      12-07-2014, 12:33 AM   #6
Slacking02
Slacking02's Avatar
Drives: M Coupé & X6 50i
I would love to do this mod! I've been searching for a walkthrough on the pin swap but came up short!
      12-23-2014, 09:56 AM   #7
n_sievers
2012 X6M  [0.00]
Here is the pin swap info:
http://www.e90post.com/forums/showth...hlight=rewired
