      03-26-2016, 03:57 PM   #1
Kingloose
Drives: X5
Tire replacement
All,
I just came back from dealership they recommend to replace both rear tires even though I have a nail in one sidewall with a slow leak. I have a staggered setup.
To make the matters worse, they just replaced the tires in December or 5000 miles ago.
Their explanation - due to tire wear this may cause a problem with differential. I've had them measure the tread depth of the current tire and that is between 8/32- 9/32
I am currently running conti dws6.
Any thoughts / suggestions if I should be replacing both ?
      03-26-2016, 08:12 PM   #2
Poppyboy
1976 Triumph TR6  [10.00]
1993 Bentley Turbo R  [10.00]
2011 X5  [10.00]
They are correct that you need to replace the tire, as sidewalls cannot be repaired. However, if your good tire has 8-9/32 vs. 10/32 brand new, screw the dealership-you don't need to replace it. Don't ever go to a dealership for tires. Biggest ripoff ever.
      03-27-2016, 08:07 AM   #3
eswimm
Drives: 2015 i8
I believe the guideline is no more than 3/32 difference between current and new to avoid problems.
Last time I bought tires at the dealership, they beat Tire Rack's price. Just make sure they price match and charge reasonable install.
Tire Rack also used to have a service to shave a new tire to a certain depth. I'm not sure if the still offer it or if it only applied to certain tires, but worth researching if you're over 3/32 off.
      03-28-2016, 03:30 PM   #4
Kingloose
Drives: X5
Thanks all. Lucky me I am only replacing one tire 340 instead of 680
      04-11-2016, 05:59 PM   #5
Kingloose
Drives: X5
Quick update... Since I have conti dws06 they come with 12 month 2-32 hazard warranty. Dealer replaced the tire at no cost. The only cost was mounting and balancing..... Thank you continental
