      09-16-2020, 03:13 PM   #1
drummr8
6MT FTMFW
Drives: 11 E90 335xi E91 6MT 12 X5 35i
Tow Hitch Wiring and Bike Rack Suggestions
I just recently picked up a Curt tow hitch/bar for my Msport E70. Main use is just going to be for bike transport - any suggestions for a bike rack that works well with our vehicles?
Also, I wasn't going to bother with the wiring harness. Is this easy to add later, or will I have to pull the bumper and go through a bunch of extra work? Does it make more sense to just add now, even if I'm not sure I'd ever tow a trailer?
Thanks
2011 LMB E90 335xi 6MT: Wagner EvoII FMIC, Catless DP, PE Mod, Cobb CP, BMC Filter, ST Coilovers, Strongflex TSB's, Whiteline RSFB Inserts, CDV Delete, Hawk Talon Rotors & PC Pads
2011 SGM E91 328xi 6MT: 3-Stage Intake Manifold, ST coilovers, 335i brake kit, drilled/slotted rotors, CDV Delete, Charcoal Filter Delete
      09-16-2020, 06:26 PM   #2
RL18
Drives: 2011 335d sport
Thanks
Why not add it while you have the bumper off? Get it done so you have it if you need it later. Instead of waiting for the wiring to tow with it. Bmw factory harness looks to be the best decision to make it as seamless as possible, but there may be a better option I don't know about
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R.
      09-16-2020, 09:50 PM   #3
drummr8
6MT FTMFW
Just because I don't currently have any plans of towing anything... But I guess that may change in the future so I guess it makes sense to just add the harness now.
      09-17-2020, 10:24 AM   #4
dudezi
Drives: X5
you can add only a 4-wire connector to have the tail light, brake light and turn signals, no e-brake, which is good enough for towing light load, and it doesn't require removing bumper to install. detailed instruction on youtube.
