      09-15-2020, 12:02 PM   #1
raedalwan
Drives: BMW X5 E70 2013
Harsh transmission shifting
Hi All
I have replaced the transmission recently by another used one but with low mileage.
Sometimes I feel harsh shifting. For example while at first gear and RPM raising and for some reason I left the gas pedal I feel harsh shifting to second gear.
What could be the reason
BMW x5 e70 n55
Transmission ZF 8HP45
      09-15-2020, 01:03 PM   #2
yco
i'm just saying
yco's Avatar
5749
Drives: E71 X6M '10 (sold)
transmission reset may solve the problem or even throttle adaptation reset can help maybe since it wont hurt to try but otherwise it can be a problem in some parts of the mechatronic.. clutch, solenoid etc..
      09-15-2020, 01:38 PM   #3
raedalwan
Already did the throttle and transmission adaptation reset and am doubt about anything wrong with the new transmission as the millage is less than 10,000Km. Could be the issue related to low transmission oil even very small than normal level?
      09-15-2020, 03:26 PM   #4
Bengineer330
Bengineer330's Avatar
Drives: Le Mans Blue 2011 E92 M3
Had the same issue with my 8 Speed, harsh shifts and jerky acceleration. I thought it was the transmission. Did a fluid/filter change and reset adaptations with no real improvement. Turned out to be the transfer case. I changed the oil and reset the transfer case adaptations. Car is buttery smooth now, 134K on the clock. I used RedLine MT-LV and have about 5k miles on the new fluid.
2011 E70 Xdrive50i M-Sport Black
2011 E92 M3 ZCP LeMans Blue
2006 E90 330i Silver - Donated after 410,000 miles
      09-15-2020, 10:51 PM   #5
raedalwan
Thanks Bengineer330, can you explain more about harsh and jerky shifting like at what speed and gears you are faced such issues and how many liters of oils used for the transfer case?
      09-16-2020, 02:20 PM   #6
Bengineer330
When accelerating from a stop there was a noticeable clunk between gears and accelerating at any speed it would be jerky as if a clutch was shifting. I did all the transmission work first thinking it was that. When I changed the transfer case oil I honestly didn’t think it would make the difference that it did. HUGE improvement. No more harsh shifts
1-Liter of fluid. I got the special tool from ECS. Took under an hour to do.
