      08-30-2020, 07:37 PM   #1
ggabriele3
Drives: 2015 228i Msport
Battery replacement - computer required?
My 2013 is still on its original battery. Due to the Covid lockdown it’s been sitting for months without being driven - now I’m getting “high battery drain” warnings.
It’s happened enough times, even after some long drives, that I think the battery has to be replaced.
Can I simply swap the battery or is this a process that needs a computer/BMW service/etc?
      08-30-2020, 08:23 PM   #2
yco
i'm just saying
yco's Avatar
5749
Drives: E71 X6M '10 (sold)
as long as battery specs are the same or almost the same no coding needed but you need let the car know that its a new battery to avoid overcharging etc and you ll need a OBD scanner for it..
      09-09-2020, 06:51 PM   #3
LOVEDMY318TI
Drives: 2013 X5
I am about to change my battery on my 2013 X5. How do I let the car know it is a new battery? An OBD scanner it will allow me to do this? Any particular one you recommend?
      09-09-2020, 06:53 PM   #4
LOVEDMY318TI
Drives: 2013 X5
I have the same issue from the same reasons. My battery is dead and will not accept a charge.
      09-09-2020, 10:19 PM   #5
Molez93
Molez93's Avatar
Drives: 2006 Z4M, 2001 740i
Requires a scan tool. A Foxwell NT520 works for me: ~$160. Picked that based on research related to this exact topic.
Pretty sure a Carly app with the right dongle will get the job done for less cash.
'01 740i Sport; ‘06 Z4M Original owner, no mods
'14 Lotus Evora S; '13 Subaru BRZ, track & autox car
Sold/totalled: E46, E39, 2 E53s, 5 E70s, E31
      09-10-2020, 10:38 AM   #6
RL18
Drives: 2011 335d sport
The problem with the foxwell tool is your battery replacement has to have the same specs as the current registered battery. All it can do is say "hey there's a new battery!"
I found mine through auto zone, it's a duralast h8-agm and used my foxwell scan tool to register it
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R.
      09-10-2020, 12:20 PM   #7
mitch808
Drives: 2012 X5 35i
I use Carly through my phone and their dongle. I think you can pay for just the battery feature vs the entire app. All of the features in the app I think can be bought ala carte.
      09-10-2020, 07:17 PM   #8
Molez93
Molez93's Avatar
Pretty sure you’re correct regarding most scan tools. However, if you get the right one (read as: spend enough), you can adjust any changes in specs. Nearly certain mine shows that feature or function, though I didn’t need to as I matched OE specs with the replacement.
RL18273.50
      09-11-2020, 06:54 PM   #9
Thecastle
Drives: F10 550i
2020 BMW M340i  [0.00]
2019 RAM 3500  [0.00]
2020 BMW X3  [0.00]
2016 BMW 550i  [0.00]
2000 Ford F450 7.3l ...  [0.00]
carly worked for me to register the battery. Though carly is buggy as hell on older andriod phones.
