      03-07-2013, 02:42 AM   #1
KrisHorton
Drives: E70 X5M and E60 M5
Faulty Injectors
So I had quite a scare on Friday evening in the X5M. I was getting on the freeway and at the top of 2nd gear, the iDrive came up with an "Engine Malfunction" warning and the car dropped into failsafe mode. Needless to say, my life flashed before my eyes and I eased off the gas quickly. I pulled into the nearest gas station and by that time the car was spluttering and surging. I had the car towed to my house since I was right down the road and I read the codes which showed a misfire on 2 cylinders. I had the car towed to the dealer the next morning and on Monday it was diagnosed to be 2 faulty fuel injectors which had in turn fouled all 8 spark plugs. I was told by my service adviser that they've had so many cars come in for this issue that they barely needed to diagnose the car...so I was glad to hear this wasn't a fluke. Care came home this evening and is running great and I'm very relieved the issue wasn't a big one.
I wanted to see if anyone else has had this problem and if they ever had it happen more than once. At least in the future I won't stress as much if it happens again.
      03-09-2013, 07:56 AM   #2
mrpcar
Drives: 2012 X5M
Search for my old posts, I reported injector issues awhile back but no one seems to have the same issue. My guess is that people just don't know, if the injector problem left unattended they will eventually experience what you've experienced.
      03-09-2013, 07:57 AM   #3
mrpcar
Drives: 2012 X5M
Here, saved you the time to search.
http://www.xbimmers.com/forums/showthread.php?t=722935
      03-09-2013, 01:44 PM   #4
KrisHorton
Thanks for the link, that's really interesting. I'm glad I wasn't the only one with this problem. I believe what happened in my case is that the two injectors went bad and fouled all 8 spark plugs by making it run too rich. The dealer tech reported all 8 plugs were "fuel fouled."
      03-10-2013, 07:22 AM   #5
mrpcar
Drives: 2012 X5M
Just curious, where do you buy your gas? One of the things the dealer did was pulling the plug and they did find signs of fouling to indicate that I had leaky injectors.
Other symptoms you should have seen is that the car is difficult to start after parked for 1-2 hours. Not cold over night, but just 1-2 hours after driven. Basically what happened is that the fuel continues to drop from the injector and causes the fuel line to loose pressure and will take extended long cranking before the engine will catch the next time you start.
      03-10-2013, 09:30 PM   #6
KrisHorton
I don't recall any hard starts or anything, so mine might have failed harder and faster.
I'm not too terribly picky with gas as our M5 has thrown a fit with Shell V-Power premium and run great on Arco premium. I know some people are super gas snobs, but I'm generally okay with most brands aside from the super budget ones.
      03-10-2013, 10:14 PM   #7
mrpcar
Drives: 2012 X5M
I've always used Costco for all of our cars, with all the recent injector problems I no longer go to Costco.
http://www.city-data.com/forum/autom...e-good-11.html
      03-11-2013, 10:08 AM   #8
BiG22DuBz
BiG22DuBz's Avatar
12
Drives: X5M
Glad your dealer didnt try and hassle you and handled it right.....knock on wood, havent had any issues yet and i use arco and 76 gas and shell and i drive like a mad man
2014 M5...AMS downpipes, BMS tune, lead foot
2011 X5M....Downpipes, exhaust, dyno tuned
2008 Ducati 848....pearl white, Termignoni exhaust
CLS55 and C6Z06 (previous rides)
