      07-03-2012, 10:51 AM   #1
lbouchard
Drives: 335XI
18" wheels on X5 5.0i, will it fit?
BMW OEM alloy
18" wheels on 2012 X5 5.0i, will they fit?
i believe 18" is a better option for winter setup.
      07-03-2012, 01:03 PM   #2
Ben_XI
Ben_XI's Avatar
Drives: 2011 x50i
Shouldn't be an issue. I have 18" for my winter set-up. Realoem also shows an 18" is available for 2012's, too.
reaoem
      07-03-2012, 02:33 PM   #3
Mammoth_Snoborder
Drives: 2012 X5 35i Sport Activity
2012 BMW X5  [0.00]
Yes, they will fit with no issues. I too, run OEM 18" with winter tires on my 2012 X 35i in the winter. They just look silly small housed under the flared fenders.
      07-04-2012, 10:24 PM   #4
cb4
cb4's Avatar
Drives: 2008 335xi
I think the 5.0 has bigger front rotors so the 35i is probably not the right comparison.
      07-04-2012, 10:44 PM   #5
watrob
watrob's Avatar
Australia
140
Drives: MY2022 X5 M-Sport 45e White
The 50i has 365mm front rotors while the 35i has 348mm.
MY22 X5 M-Sport 45e White, 22"rims, Red Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, otherwise all option boxes are ticked.
      07-05-2012, 11:08 PM   #6
xDrive35i
xDrive35i's Avatar
Drives: Porsche Macan S
You all are forgetting that the base 50i rides on the 18" rims that the 30i used to ride on pre-LCI.
      07-05-2012, 11:37 PM   #7
watrob
watrob's Avatar
Australia
140
Yes, but does a base model 50i that comes with 18" wheels have the 348mm rotors and 50i ordered with factory 19" wheels (or M-sport) have 365mm rotors. By the time you add the splash gaurd and the caliper it must be a tight fit.
If your running 18" on a 50i what rotor do you have?
      07-05-2012, 11:43 PM   #8
watrob
watrob's Avatar
Australia
140
Here is a photo of my previous M-Sport with 365mm rotors with the factorty standard 20" m-wheel.
It would be close call for 18" to fit..............
      07-05-2012, 11:53 PM   #9
watrob
watrob's Avatar
Australia
140
Heres a photo of the M50d, rotors are 385mm with 20" rims, there is now way you would get 19" on.
