      05-07-2020, 02:56 AM   #1
Phil325i
Phil325i's Avatar
Drives: E92 325i MSport Coupe
Vacuum Controlled Engine Mounts
Hi. Please excuse my incursion from E90Post but a member there suggested I try here.
After 100,000+ miles I'm about to swap my OEM engine mounts (called 'motor mounts' in the US I believe!) for a pair of 034 Motorsports Street Density mounts. These are solid rubber, not oil filled.
My issue is that on close inspection I find my factory-fit mounts are vacuum-controlled. There is a vacuum line linking each mount and a line heading to a vacuum source somewhere in the engine bay.
I'm thinking I can fit blanking plugs to the vacuum lines and then use the solid mounts without issue. Am I wrong? Does anyone have any experience of substituting vacuum mounts with solid? I believe X5 diesels have these. Any advice appreciated.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
