      03-10-2020, 10:12 AM   #1
cstk421
Drives: 2013 X5d M57 E70
13 x5 35d Acceleration issue
Experiencing a no boost acceleration problem. At WOT it limps along until finally it takes off full power happens consistently. Once to speed it drives fine. Also when WOT and RPM gets high enough vehicle shutters and goes to limp mode until I pull over and power off and back on. Only code is 00433B Boost pressure sensor range (which hasn’t come back since clearing).
Thoughts ?
Claudio
      03-10-2020, 11:49 AM   #2
RL18
Drives: 2011 335d sport
Originally Posted by cstk421 View Post
Experiencing a no boost acceleration problem. At WOT it limps along until finally it takes off full power happens consistently. Once to speed it drives fine. Also when WOT and RPM gets high enough vehicle shutters and goes to limp mode until I pull over and power off and back on. Only code is 00433B Boost pressure sensor range (which hasn't come back since clearing).
Thoughts ?
Claudio
How do your turbo vacuum lines look? How many miles? Emissions intact? Have you checked for carbon build up in the intake?
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R.
      03-10-2020, 04:00 PM   #3
cstk421
121k
Emission system is deleted
Intake is clean
Vacuum lines are good
New guess is Mass airflow sensor issue ?
Also when car is cold accel issue doesn’t show. Only when car is warm.
      03-10-2020, 04:44 PM   #4
RL18
121k
Intake is clean
Also when car is cold accel issue doesn't show. Only when car is warm.
If you haven't replaced your EUVs or boost pressure solenoids they could be bad also. That's what I think your issue is since you mentioned shuttering.
I had a bad MAF sensor and it was going into limp instantly. You can check the MAP sensor also.
      03-13-2020, 12:34 AM   #5
jv004
Drives: X3M Comp
Had same issue on mine, replaced both turbo boost solenoids and fixed the issue, around the same mileage when it happened. Didn't get a CEL for a while. If accelerated really slow then once it moved up in gears the second turbo kicked in and got a little faster. The solenoids gets clogged after a while until there's no boost, seems around at 100k plus miles
