      08-22-2018, 01:51 PM   #1
Cyphon
Drives: 2011 BMW X6 35i
MA Inspection with MHD tune
As titles says, it's that time of the year.
I have MHD installed for Stage 2+ with catless downpipes installed. When I first flashed it, I UNCHECKED the OEM/Cats box. When I plugged in the OBDII reader, the cats read INC as it should, EVAP was OK, BUT the O2 Sensor read N/A.
Will I pass inspection considering Cats INC will be the 1 incomplete that I am allowed or will the O2 Sensor being N/A fail me?
Note: I reflashed and CHECKED the OEM/Cats box (yes even when I have catless downpipes), my O2 became OK after driving for a bit but EVAP takes forever and also I get P0420 code. I'm thinking the code came on because the car is confused because I have no cats and it's thinking I do. But I'm sure I'll fail inspection leaving it in this state.
Anyone got any input on this?
      08-26-2018, 12:59 AM   #2
rediahad
Drives: E71, E93, E92
on my 335i there is a thing called a downpipe fix if you dont want to install your stock cats. MHD makes that a shadow code
      08-27-2018, 05:11 PM   #3
El Wray
Drives: AW X6M
CEL = fail.
      08-29-2018, 12:30 AM   #4
vympel777
vympel777's Avatar
31
Drives: 540 B58 MSPRT \ F16 5.0 M SPRT
Where to get that shadow code I'm interested as well. I need it for F series.
      09-02-2018, 08:45 PM   #5
rediahad
it's not a shadow code, mhd makes the downpipe code a shadow one which means that it doesn't trigger your check engine light with the flash but your ecu is still reading it as a CEL check vrsf.com it's called a downpipe fix.
      09-19-2018, 07:47 PM   #6
vympel777
vympel777's Avatar
31
I have the same stage 2 and also worry about NYC inspection. I have no check engine lights with MHD tune. Will i pass it?
      09-19-2018, 07:51 PM   #7
vympel777
vympel777's Avatar
31
I actually never got the CEL error. Before I tuned my car i was getting an error for O2 SLOW RESPONSE" CODE.
      09-19-2018, 07:52 PM   #8
vympel777
vympel777's Avatar
31
So Cyphone, did you pass it or not lol?
      09-24-2018, 01:14 PM   #9
Cyphon
Sorry for the late response. But yeah I passed. What I did was I reflashed MHD Stage 2+ BUT I CHECKED the "OEM/Cat" box even though I'm running catless. I installed a flouer on the O2 sensor moving it like 1.5 inches away from the downpipe. I cleared all the codes and drove for a bit.
I checked for codes again and it was good, everything turned ready except for Evap and in MA you are allowed one incomplete so I passed with that.
But sadly after all this headache of trying to pass inspection and constantly flashing the car, I got a 2DD8 code which my valvetronic servo motor is malfunction so that will require repair.
