02-27-2017, 03:33 PM | #1 |
Rep 136
Drives: X5 35d X
Squealing Brakes
I have searched this great site on issues about squealing brakes but I'm still baffled about my brakes. I had BMW install new brakes all-around 6000 miles ago and I'm on my third set of front rotors being replaced as they're telling me they are warping. But my biggest concern is the last two months with the cold weather my brakes squeak so loud it's driving me nuts. When the weather warms up, no squealing at all. BMW ended up chamfering my pads and it did nothing, Now it's going back to the dealer again and I'm just wondering if someone with some mechanical knowledge can give me some insight as to why they squeal when the weather is, cold but are fine when it's warm outside.
Oh ya I now know now what my first mistake was..... |
03-02-2017, 10:08 PM | #2 |
Rep 136
Drives: X5 35d X
Update, Today BMW took all the brakes apart cleaned everything up and chamfered front and rear pads. They tell me it's because they have no asbestos in them and it's the brake dust that causes them to squeal like a taxi cab. I hope it works as I'm tired of getting the looks like you drive a nice vehicle but you can't afford brakes.
03-03-2017, 01:49 AM | #3 |
Rep 728
Maybe go aftermarket and put anti squeal on the back of the pads when installing. Bleed the brakes and Make sure you properly bed-in the pads and rotors to prevent warping. I kind of think your problem is the dealership.
03-03-2017, 06:51 AM | #4 |
Rep 2,037
Drives: 2022 X6///M Comp
I'm assuming you're talking an E70 being this is the E70 forum....
Brakes on all my previous BMWs - E53, E70, & E71 - only squealed when brakes were dirty from the accumulated brake dust. My F86 however is ridiculous and sounds like an old school bus EVERY FREAKIN TIME I HIT THE BRAKES. It makes my ears bleed. I have heard that it has something to do with the composition of the brake pads. I thought it was specific to the M brakes but maybe they changed the materials they use in all the brake pads? Either way, it is very annoying. |
03-03-2017, 10:05 AM | #5 |
Rep 136
Drives: X5 35d X
Aftermarket will be my next choice for brakes. I went with Bmw as my original factory brakes lasted 55000 miles and that's with towing a trailer which I thought was good.
03-03-2017, 10:22 AM | #6 | |
Rep 136
Drives: X5 35d X
03-03-2017, 12:45 PM | #7 |
Rep 994
There is no such thing as warped rotors. It's a myth. BMW is about as clueless to the problem as you.
That said, pad material, backing plate quality, or small pebbles stuck somwhere are all common reasons. changing to a ceramic pad compound over semi-metallic is an option greasing well and using anti-squeal gel/paste behind the pads are usually the first place to start. replacing parts willy nilly is absurd, but makes the customer feel great. |
03-03-2017, 06:51 PM | #8 | |
Rep 136
Drives: X5 35d X
BMW change the rotors that they say we're warped and the steering shake went away and may have had something to do with the squealing. Unfortunately I had to return to the dealer for them to try to solve the problem. It must be the pad material they use but as of today no more annoying squeal but it's a warm day here, I'll see what next week brings when the temperature drops. |
03-03-2017, 11:50 PM | #9 |
Rep 6,708
@Mitch808 is right. What you're feeling are pad deposits being formed on the rotor surface, which then harden to diamond like deposits. You will feel a judder under high or hard braking conditions.
There's an excellent article from Stoptech here http://www.stoptech.com/technical-su...nd-other-myths |
03-04-2017, 02:14 AM | #10 | |
Rep 728
