      07-21-2012, 10:00 AM   #1
exfyvem
exfyvem's Avatar
18
Drives: 2012 X5M
Stage 2 X5M shifting problems.
So, my X5M has velos stage 2 tune with race-catted downpipes, de-resonated midsection, and gthaus exhaust. About 2 days after i got it back from getting the downpipes installed, i went to shift out of 1st gear pretty high up in the rev range it jumped, and felt like it missed the shift into 2nd gear. The car is putting out about 700hp and 680lb/ft. Not quite sure exactly what happened, but i let my foot off the throttle and thought i destroyed my transmission. After that, it has been acting completely fine (about 1000 miles since then), but i have been trying to stay away from hard shifts out of 1st. Yesterday, i tried the same thing again, and it felt like it missed the shift... again. Im not sure if this is a problem with the transmission or if it simply just can't keep up with how fast the car revs from first. Hard shift out of any other gear go just fine, i only encounter problems out of 1st. Any suggestions/input would be nice. I'm not under warranty any more (obviously), so i just wanted to see if anyone here had any ideas of what the problem may be before i go to BMW and get my balls busted.
2012 X5M, 2012 Panamera Turbo, 2011 Maserati Granturismo S (sold), 2006 Range Rover HSE
      07-21-2012, 10:21 AM   #2
BabyBlack
BabyBlack's Avatar
27
Drives: E46 M3 & E90 335i & E71 X6M
Sorry to hear that OP, I found this truck's drive train can't handle that much power, I have heard other has broken the axle, transfer case, and now missing shift with upgraded tune. I guess this is always true that "you have to pay to play". Wonder if Velos has any upgrade tune for the TCU that can go alone with their ECU tune.
      07-21-2012, 12:45 PM   #3
mrmomo313
mrmomo313's Avatar
Drives: M6 Gran Coupe
you're putting out a ton of power, i have the dinan tune on mine and i find it so hard to shift out of 1st gear with the paddles because it literally passes through that gear in no time. have you tried a full throttle run in just sport to see if it shifts correctly? my guess is that its just to hard to shift out of that gear in time (hopefully nothing is wrong with your tranny)
      07-21-2012, 03:28 PM   #4
Biff Grissel
stankmouth
Biff Grissel's Avatar
Drives: fun
sorry 2 hear bud, doesnt sound good but lets hope its just a computer adjustment issue. i would def have it looked at before u do anymore driving 2 avoid a bigger issue that may be caused by this. good luck, keep us posted.
      07-22-2012, 10:16 PM   #5
northern2020
northern2020's Avatar
Drives: '11 X5 M / '01 B5 S4/ 15 328d
1) sounds like a tranny issue
2) call the tuner
3) before going to BMW I would advise going back to stock or you may end up with a large non-warrantied claim
4) no offense but without a larger turbo upgrade and a new intake/manifold (like Hamann) here is no way your at 700hp...
| '10 Escalade ESV | '12 Audi S4 | '01 Audi S4 | '15 328d Xdrive M-Sportwagon |
      07-23-2012, 10:11 AM   #6
SflBimmer8484
SflBimmer8484's Avatar
1467
Drives: .
Sounds like a transmission torque maps problem.
      07-23-2012, 10:55 AM   #7
Blitzblau
Field Marshall
Blitzblau's Avatar
Drives: 2012 Black Saph Metallic X5M
Granted I haven't done as much to mine as you have to yours...I also have the Velos Tune and everything is running perfectly fine as of now and probably 3000 miles into the tune. If not, more.
I would go back to stock ECU...see if that rectifies the situation, maybe also while it is back at stock, take it in and make sure everything is fine with the tranny.
Omar will definitely do everything in his power to make sure your tune is perfectly mapped to your mods. The guy is definitely customer service oriented.
I am pretty sure you aren't going to mess up that tranny though...it is pretty much the reason they used it instead of the DCT.
Good luck and please keep us updated...I am intrigued.
2008 Interlagos Blue E90 M3 (Retired)
2012 Black Sapphire Metallic X5 M (Velos Designwerks Tune, LUX H8 V3 Angel Eyes, Black Sapphire Metallic Kidneys and Roundels, M floor mats
2009 Black Cadillac Escalade Hybrid
      07-25-2012, 08:21 PM   #8
novablackm3
Drives: Performante, G05 M50i, RR SVR
sorry to hear about that,
btw any pictures of your de-resonated mid section ? i have down pipes and was thinking of doing that and keeping the stock exhaust
Huracán Performante 18- Novitec Springs | RR SVR 19 | G05 X5 M50i | E70 11 X5M retired |
Jerez Black E92 10 m3 RE SSK | AFE Filter | Fabspeed XFC / Xpipe | AA ECU 1.5v | BMW PSW | Envy Charger | Megan Exhaust
      08-10-2012, 09:34 PM   #9
BiG22DuBz
BiG22DuBz's Avatar
12
Drives: X5M
I have the same symptoms too only in the 1-2 shift. To get a perfect sounding 1-2 whaaaaapppaaaa shift, lay off throttle a bit around 5500ish rpm's and manually shift with paddles or shifter.
2014 M5...AMS downpipes, BMS tune, lead foot
2011 X5M....Downpipes, exhaust, dyno tuned
2008 Ducati 848....pearl white, Termignoni exhaust
CLS55 and C6Z06 (previous rides)
      08-11-2012, 09:03 AM   #10
Jimshorts
Jimshorts's Avatar
19
Drives: x5m
I've noticed this and my truck is still stock... I would do what big22dubz said just lay off it a bit and shift a little sooner. I've been saying this since day one that first is gonna become non existent once I get my tune. Do a good hard pull in sport and let the truck shift I'm sure you won't have problems.
Also toss that bad boy on a dyno and give us some numbers to the wheel... Tired of hearing crank numbers. What gear has the 1:1 ratio? 3rd or 4th?
      08-12-2012, 10:44 AM   #11
Dansarkis
Drives: M5, i8, V10 R8 Twin turbo
Any updates on this?
Does it just happen with the paddles or in sport auto too?
Just ordered Stage 2... :-/
2014 M5 Comp, Dinan P1 708hp -- Daily
2015 BMW i8 Pure Impulse World
2011 Audi R8 V10 Spyder, Twin turbo, MAN PEDALS!
Grave yard: 14 1100hp GTR, 11 Twin Turbo R8, 13 M5, 09 LP-560, 14 GTR, 08 R8 V8, 11 X5M 700hp, 10 E93 M3, 08 E92 M3, 06 E46 M3 CP, 02 E46 M3
      08-14-2012, 09:47 AM   #12
Omar@VelosDesignwerks
Omar@VelosDesignwerks's Avatar
Drives: Different Ones
In manual mode you have to remember this is not a true manual transmission or a DCT transmission. Remember when you try to floor it out of first and then manually shift you may think you are at redline but the shift is 'delayed' which is going to make you feel like you hit a wall. You are basically trying to shift at 6800-6900 but the shift doesn't take occur how it would in a true manual transmission.
Drive it in sport and the issue should not be present and this is because the car is shifting at its optimal point. Give me a call and we can talk about it... or anything else for that matter
No.
Wise man
Nothing to worry about boss.
      08-14-2012, 09:51 AM   #13
Thanks for the kind words!
      08-14-2012, 09:59 AM   #14
[Deactivated-Velos]
Drives: M
Hey,
Keep in mind when you manually shift using the paddles the action will be slightly delayed as while the transmission may be pretty advanced it is still an auto. Not a DCT or manual variant.
You are not mis shifting you are hitting redline.
In a safe environment, put the car in sport and floor it in first, the issue will not be present.
Also note, anything causing an issue would cause a CEL first.
      08-14-2012, 05:22 PM   #15
exfyvem
exfyvem's Avatar
18
Drives: 2012 X5M
Everything is working fine, thanks so much to Velos for showing concern and doing everything they can to help solve the problem!
      08-14-2012, 11:56 PM   #16
northern2020
What was the problem?
Or was there no problem - just as stated a shifting lag because of the auto tranny / no DCT?
      08-15-2012, 08:52 AM   #17
Blitzblau
Field Marshall
Blitzblau's Avatar
Just curiously, I tried to recreate the issue and yeah...in manual mode you need to be hitting the paddle around 5.5k in order to not hit the redline. I was in fist/M mode/manual and mashed it...shifted at 5.5 and it was a nice shift anything past that and I seemed to get to the redline VERY quickly.
Glad all is well...
      08-15-2012, 09:23 AM   #18
Glad all is well...
      08-15-2012, 10:08 AM   #19
Blitzblau
Field Marshall
Blitzblau's Avatar
Originally Posted by Omar@VelosDesignwerks View Post
Omar...you are the man!
