      05-31-2015, 09:57 PM   #1
igorbmwx6
igorbmwx6's Avatar
Drives: 2016 BMW 328i F30
Rough shifting from 2nd to 3rd gear
I have a 6-speed transmission. When transmission is in "D" mode, you cannot even feel when gears a switched. However, when transmission is switched to either "D/M" or "Manual", then switching between all gears is smooth except for 2nd to 3rd gear, which feels a little jerky. I have already replaced transmission fluid and filter few thousand miles ago.
Is anyone else experiencing the same thing with BMW 6-speed transmission?
      06-01-2015, 01:32 AM   #2
Jess///M
Drives: 2016 X6M
Hi Igor! The S mode is rougher for me, too, esp 2nd to 3rd. It's been that way all along in my case. I have the Dinan tune, also. I have not gotten any transmission warnings since new, so thought the aggressive shifting in S was normal.
      06-01-2015, 09:38 AM   #3
igorbmwx6
igorbmwx6's Avatar
Thank you for the feedback, Jess. I am also hoping that this is normal. Since in "D" mode shift from 2nd to 3rd gear is as smooth as from any to any gear. I also found information that ratio difference is the most between 2nd and 3rd gears on those BMW ZIF 6-speed transmissions. Maybe that's the main reason then switched to 8-speed in F models, to resolve this issue of rough switching between 2nd and 3rd gears.
      06-16-2015, 09:00 AM   #4
txpander
Bulgaria
Drives: BMW X6 xDrive 40d
Mine shifts rough from first to second and sometimes from second to third with cold engine, not sure if that's okay.
      06-22-2015, 11:17 PM   #5
igorbmwx6
igorbmwx6's Avatar
I am not sure either. There are no other symptoms of any failure. Just wanted to see if anyone else with X6M E71 has the same issue.
      06-23-2015, 06:15 AM   #6
txpander
Bulgaria
I'm bringing mine for a full check next week on Tuesday, and will also ask if rough shifting is okay on a vehicle with 20K miles on it.
I'll keep you posted.
Tags
2nd to 3rd gear, 6-speed, rough, transmission
