      05-01-2024, 03:23 PM   #1
Belekaa
Drives: E70 40D
E70 40D n57 EGR problem.
Hey guys! Having some trouble finding problem for X5 40D. At about 2k Rpm on highway speeds i get CEL which disappears instantly, at same time i feel car a little bit jerks on around 1.7-2.2k rpm,happens more often when going slightly uphil, but not everytime.. i changed 2x EGR valve, done adaptions but nothing helps. First EGR valve that i changed was aftermarket one, second is used original, which have been problem free. Codes i get is :
40D4 DDE: Exhaust-gas recirculation controller, position control
4C9E DDE: Exhaust-gas recirculation valve, plausibility
4C9F DDE: Exhaust-gas recirculation valve, plausibility
Last two are stuck open and stuck closed.
Maybe some people have seen something like this, please show me the right path without spending a lot of money just throwing in new parts.. I can plug Ista if anyone need some data off it. Or could it be that i have too old ISTA version (4.01.21) And adaptation cant take a place?
      05-02-2024, 09:40 AM   #2
wcs531
Drives: E90 335xi / E70 X5d
I would search and post in the F15 forum for the N57 engine. We never got the N57 in the E70 in the states.
      05-10-2024, 01:59 AM   #3
Cnoro
Cnoro's Avatar
Albania
14
Drives: Bmw e70 4.0d xdrive
Hello
I have changed all my Vacuum Hose ( 3.5 X 7.5 mm ) about 6 meter long
did you try this?
      05-10-2024, 09:54 AM   #4
Belekaa
Drives: E70 40D
Problem found already. It is Egr flap actuator, it holds no vacuum. Changing it tommorow. Its hard to reach it on 40d need to remove entire cooler.
